My '98 V70 GLT w/115k has developed an annoying habit of an occasional rough idle on cold starts. I'm thinking that it's moisture related because I think that every time it's happened has been after sitting for an extended period after torrential rain, like the hurricane we had this week.
It fires up, but the idle is very rough, almost a rumbling/chugging sound with excessive vibration for about 15-20 seconds, after which time it smoothes out and runs fine. There is no CEL.
Plugs, wires, caps are all less than one year old and are OEM. Battery is also only one year old.
Thoughts? Anything specific that I can check?
Rough Idle Cold Start Moisture?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Could be a number of things. Low fuel pressure at start, vacuum leak, IAC valve sticking, coolant temp sensor going bad, etc. You'll have to have it trouble shot.
Well, temp sensor is a couple years old, and OEM. IAC has been cleaned.
Wouldn't a vacum leak manifest itself more when the car is hot and hoses have expanded?
This happened last summer too, after a huge rain. I changed the caps and wires and it hasn't happned agin until now. I am hoping it is water related.
'98 V70 GLT
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Check that the hood seal is intact between the windshield and hood. I had a tear in it, and it would leak down directly on the cam sensor/spark plug area and cause a hard start sometimes after a hard rain.
'98 S70 T5
2016 Chevy Cruze Premier
- 1960 Views
Last post by towanas
- 938 Views
- 962 Views
Last post by sweedespeed1
- 3794 Views
Last post by WhatAmIDoing
- 17 Replies
- 1494 Views
Last post by vtl
