Dear all,
The ecc fan in my '98 V70 behaves somewhat strangely these days. I always drive with the fan in "auto". Sometimes (every other or third drive) the fan will intermittently go to max speed for a second or two - much like when the temp setting is changed - except I do not change the temp setting. Other times the auto function of the fan does not work at all and the fan will stay on low regardless of temp setting and engine temp. This is solved by turning off and restarting the car. All of this happens both with A/C on and off. I do not have blinking lights in the ecc control panel.
Any input on how to solve this is appreciated.
Nikolaj
ECC fan speed control
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
My guess would be the ignition switch.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Yeah, mine did this. That thing has a mind of its own sometimes.
Try blowing out the temp sensor next to the defroster switch with a can of compressed air.
'98 S70 T5
2016 Chevy Cruze Premier
rspi wrote:My guess would be the ignition switch.
Nikolaj
Ah yes, the usual suspect! Will dojblackburn wrote:Yeah, mine did this. That thing has a mind of its own sometimes.
Thanks for your input
- 1130 Views
Last post by Stoneworks
- 4944 Views
Last post by CRM
- 14 Replies
- 2951 Views
Last post by rsmigel
- 453 Views
Last post by JimBee
- 512 Views
Last post by jreed
