850 Engine Swap
Just purchase a 850 96 t5 engine and planning to install into my current 850 96 GLE. Changing the entire engine bay wiring to T5. Do I still need to change the internal wiring or can I use the existing GLE internal wiring since both are OBD-II. Thanks.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Cam sensor is the same. Check the knock sensors for likeness. As far as the crank sensor it should be the same too. It's only when things went to '99 when NA that sensors changed to Denso. The engine computer may be the next thing to ask about. I have a friend in Sydney that did the same swap from a GLT to T5 engine and he said the computer adapted to the higher boost engine. He retained the T5 turbo (is it 16T?)
- 15 Replies
- 5263 Views
Last post by soulvoid21
- 1159 Views
Last post by MadeInJapan
- 17 Replies
- 6453 Views
Last post by henrysin44
- 14 Replies
- 1048 Views
Last post by jonesg
- 1863 Views
Last post by tryingbe
