I was wondering if anybody used Plasmaglow or any other brand Bright LEDs undernight the headlights on C70 2006+ (mine is 2009) if yes, how did you route the wires and where did you hook up?
http://www.plasmaglow.com/lightning-eyes-headlight-kit/
Thanks, in advance,
Matt Kas
2009 C70
San Clemente, So Cal
LED Headlight Kit ?
reverend
- Year and Model: 2006 V70 2.5t
- Has thanked: 2 times
- Been thanked: 3 times
You could connect them to your parking/running lights (turn on your light one click and see what lights up). That way they'd be on as parking lights and also with the headlights. Or you can tie them in to the headlight circuit and they're only on with the headlights.
If you want to get creative, you can tie them to the running/turn-signals so they're on with the parking/running lights AND flash when you hit the signals.
I don't know the wiring on a C70 so I can't tell you specifics, but a volt meter tracing wires from the bulbs and back will tell you the easiest spot to connect them.
