(Apologies in advance if this has been asked before -- at work right now and didn't see this come up in the forum search)
I did see the following (www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=17449), but was unsure if this was possible as well without any issues? Also, I need to know the proper Bosch part number as well as part numbers for the 3 hoses leading from the boost regulator? Thanks.
'95 850 T5R ecu swap to a '96 855 Turbo?
boreddaily
- Year and Model: 1996 855 Turbo
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
You need to have the same emissions system on both cars (EGR or air pump). M 4.4 cars have an air pump; M 4.3 cars have EGR. Look for a small-diameter tube off the front of your air box and the SAS valve on top of the exhaust manifold.
If they're both equivalent, the ECUs will swap with no problem.
It may net you a few extra HP (like 10-15), but I really don't see it as worth the time. A tune would be your best option for more power. Not sure how that guy got 14 psi out of his, but it shouldn't really boost that high.
'98 S70 T5
2016 Chevy Cruze Premier
- Year and Model: Many Volvos
- Been thanked: 76 times
The boost control valve is the same between the R and the standard T5 (pn 127630). The hoses do have a part number but it is bulk vacuum line sold by the meter. I bought metric silicone lines from O'Reilly Auto Parts on the last one that I re-did the hoses on.
The '95 ECU might have some issues going into a '96. The speed sensor waveform is different. On the '96 it is a digital pulse train from the ABS module. On the '95 it is a sine wave that comes from the vehicle speed sensor on the transmission.
boreddaily
Thanks for the info, fellas
- Has thanked: 312 times
- Been thanked: 818 times
For the record, the speed sensor issue is probably fine. In my 95, I can readily swap between 95 and 96 ECUs. It is the other direction from the question here, but the speedo works fine with either ECU. The only issue is I removed the EGR, so when the 95 ECU is installed the car throws a code for no EGR signal.
- 11 Replies
- 3167 Views
Last post by tryingbe
- 4581 Views
Last post by Clemens
- 2419 Views
Last post by bmdubya1198
- 1625 Views
- 453 Views
Last post by Sommerfeldt
