Problem with MBC
RobTarD
Year and Model: V70R, 1999
Post by RobTarD »
I have an 850R with a RICA tune that would boost to just about 1 bar. Today I bypassed the stock BCS with an MBC hoping to get a few more pounds of boost out of it but I couldn't, even with the knob cranked all the way down.
I took it on the highway and did a few pulls and was boosting to around 12 psi with the transmission in "Sport" mode but if I switched it to "Econ" I could boost to the full 1 bar, but no more. I also saw several pounds of fade.
I can hit 1 bar in either mode when accelerating from a stop but it doesn't hold.
Is my MBC kaput or is there something else awry? All I'm looking for is maybe 18 psi maximum.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Mine fades as revs rise in any gear. I don't know if that's expected or means there is something wrong. I suspect it's expected. I have an R ECU in my '97 T5. It's been hitting 17psi lately, when the air is cold and dense. All summer it was 16psi.
Also -> Amazon link
RobTarD
Post by RobTarD »
I've never been able to boost past 1 bar. Could the CBV be giving out at high boost? I have an IPD replacement that I haven't installed yet so I should probably do that first.
matthew1
Site Admin
Post by matthew1 »
Absolutely, install that CBV. I too have one waiting to replace my original. My 850 has ~120k miles in case you're wondering.
https://www.box.com/shared/zdjf64r3k3 that's a CBV DIY.
Also -> Amazon link
RobTarD
Post by RobTarD »
Alright, I just went out and did a few pulls with the wastegate disconnected and still couldn't boost past 15 psi. Would this be a problem with the wastegate itself? I fiddled with the actuator arm and it seems to be working properly.
ARD-Lucky
Year and Model: 1994
Post by ARD-Lucky »
If the wastegate line is pulled from the wastegate actuator and the car still won't boost past 1 bar then the CBV could be at fault, it's not terribly likely but a quick vacuum test on that line will tell you. The CBV should hold vacuum when tested with a vacuum pump. Some slight loss is acceptable but should be minimal.
Other issues that might cause that are:
Clogged cat or exhaust
Restricted intake
vacuum/boost leaks
Wastegate arm not fully seated in the turbine housing (tap from above with hammer to seat)
Just a few thoughts, let me know what you find!
-Lucky
RobTarD
Post by RobTarD »
I'm kinda hoping it's a clogged cat so I'll have a real excuse to upgrade the exhaust....
I have an IPD intake, Snabb fresh air pipe, and silicone hoses throughout so I doubt it's something on the intake side. I've had the CBV sitting around for a while but haven't had the time to install it.
I won't be able to get to it until next month so for now I'll have to settle for "only" 15 psi. :wink:
