1989 740 won't start
1989 740 turns over will not start. replaced rotter cap & button ,spark plugs ,wires ,fuel pump relay , support relay ,crank shaft position sensor ,checked spark plug #1 it is getting gas ,the spark plugs are getting spark ,any ideas?
Reason: Edited subject line for clarity.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
There is a radio noise suppression relay on the coolant reservoir which can go bad and cause a variety of symptoms including no start. There should be two identical relays on the bracket. One is the noise suppression relay which actually controls the injectors and the other is the coolant fan relay. You can switch them over to see if you do have a faulty relay.
The 1989 740 should be fitted with an On-Board Diagnostic (OBD) unit which can be used to read diagnostic trouble codes. Does your car have this unit? Look behind the left strut tower for this:
If the unit is there instructions for its use are pinned at the top of the forum.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 3683 Views
Last post by volvolugnut
- 1057 Views
Last post by rgk
