IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
S70 ignition switch question
850 LPT
Year and Model: 96' 850
Has thanked: 64 times
Been thanked: 43 times
Re: S70 ignition switch question
Post by 850 LPT »
This is kind of what I was suspecting. The cover for the connector is missing and you can pull the terminals right out. You need to check if the wires go to the right location. I took a snapshot of the arrangement from the Volvo diagram, I just happen to to look at this, because I'm doing the same thing as you. Check this out, it's for a 98:
98 Ignition Switch Diagram
Ignition Switch Diagram.JPG (41.71 KiB) Viewed 1518 times
I hope this helps.
96' 850 sedan, base, auto, pewter/charcoal, 117k miles
99' S70, base, 5-speed manual, nautic blue/ tan, 216k miles
04' V70, auto, ash gold/ tan, 233k miles, daughters car
05' V70, 5-speed manual, loaded, mistral green/ tan, 150k miles
79' Ford Capri S, Euro Spec 2.8 V6, T9 5-speed manual
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
North42g
Year and Model: 850 GLT, 1995
Post by North42g »
Wow! That's a great wire schematic(factory OEM always is). I've been using Mitchell Thanks for your help guys.
So the question remains: Which wire carries battery voltage to engage the starter motor? The R-SB?
The OE diagram doesn't line up perfectly with the actual vehicle. I do not see the markings that represent the Yellow wire w/ white stripe? I have not sent battery voltage down either wire yet, I want to now which one powers the starter for sure before I test. Thanks Guys
1995 850 GLT Estate -190k
1998 S70 -233k
2003 VW Jetta 2.0L -130k
1994 Saturn SC1 -288k ..and still going strong
1969 Ford Bronco 302 -119k
Year and Model: Many Volvos
Been thanked: 55 times
Post by Ozark Lee »
The Green / Red wire typically powers the solenoid on the starter (it does on my 850s). That makes sense from the switch diagram as well since the Green/Red is associated with pin 50 on the switch.
North42g
Post by North42g »
I'll give that a try today...at some point.
This vehicle also has a few other problems...I've been reading that they could be related....
The power windows do not work, ever. (I can jump the power window motor to raise and lower the glass. So its an electrical issue.)
The power locks do not work when commanded from the door switch. They will however work when commanded with the key FOB.
Now, I bring this up only becuase I have a hunch they are related to the Ignition Switch failure. Well, not a hunch actually...I read the Schematics & Diagrams. I also found some reading on afew other reliable technician oriented sites I use. ( IDENTIFIX & iATN) I'll post the links to these sites below, However you may need a membership. (I think one of them is free).
Can anyone confirm this corelation between Ignition, Power Door Locks & Power Window Switch Electrical Failures?
It looks like the Door locks are a part of the circuit...but the Window Switch?
I would really enjoy seeing this Volvo Driving & working properly. I have put a lot of effort into this machine. Someday I will tell the story of how I came into this particular Volvo and my overall facination with Volvo's in general.
Again, thank you to whomever is putting this site together. It's nice to have this wealth of knowledge all in one spot.
1998 S70 -233k
North42g
Post by North42g »
Oops! I forgot to post those links:
www.iATN.net
www.identifix.com
1998 S70 -233k
Whitebird
Year and Model: 1999 S70 Base manual
Post by Whitebird »
For any 1999 S70 (Base) owners looking through this thread, our ignitions are wired a little differently than the 1998. Here's what mine looks like: Image
travelling man
Year and Model: s70/1998
Post by travelling man »
Gentlemen,
I am completely confused after looking at the wiring diagram. My care to remove the cap to get to the retaining screw had only 3 wires move, 2 completely out: Y & BL/R and BL/Y loose next to Red.
So my switch wiring from the top of the 'D' (where the wires come in) counter clockwise;
BL/R, Y, R, BL/Y, N/C, R/BK, GR/Y, Y/VO, Y/WT.
It looks like I have the Y and BL/R reversed but the N/C is a different location, diagram has N/C after Red, mine is after the BL/Y. Also, I have a Y/WT to GN/R on the diagram.
I thought I had 2 wires reversed due to the fact that the engine continues to run until the key is removed. Strange or neat? Suggestions?
Jim
S70/'98
Year and Model: 2004 V70 2.5T
Been thanked: 153 times
Post by cn90 »
I thought someone already posted the diagram for 1998 model above (previous page of this thread).
Here you go:
