Baro Sensor 1275342 fix - P0108 cel gone Topic is solved
orleec
Year and Model: 98 V70 GLT'ed
Post by orleec »
Also referred to as Altitude Sensor, as well as MAP sensor - uber expensive new.
I cleaned it using 'mild' CRC MAF sensor cleaner - I removed it, gave the hole underneath a couple of spray using the supplied hose and reinstalled. I then cleared the cel using my OBDII code reader. Been over a month and cel did not return.
Don't use brake cleaner for the love of anything holy to you.
And as always, do at your own risk.
Click me to save $150 on 94-98 Turbo Cooler Lines
* SOLD - 98S70 Blk/Blk T5M B&G/Bilstein, 17psiST, R-mani, 3"dp/obxExhaust, SASdel
* 98 White V70AT GLT'ed - LPT motor swapped
* 06S60 2.5T Blk/Blk - wife's DD
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I did the same thing, it worked great.
Another option is to spray some lubricant in it (such as WD-40), let it drain and re-install.
orleec
Post by orleec »
Yup, like I said in another forum - 6 months/10k later, still no CEL.
jdifelice
Year and Model: 2000 v40
Post by jdifelice »
Where is this sensor located? Cant tell from the photo.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Close to the washer fluid tank, near the back of the passenger side headlight.
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
You guys were lucky! Cleaned mine a few times and the code kept coming back! Should have checked a junker instead of paying ~ $120 for it.
Live and learn...........
M1 10W-30 HM
orleec
Post by orleec »
Sorry to hear that, I guess you're in a hurry as it can be had for a fraction of that amount here via wanted post for those with no access to junkers nearby or otherwise could not find any.
