Bigger turbo on Lpt engine
Japedo
Post by Japedo »
I have a 15g turbo and fuel injectors out of a 95 850t with low millage on the shelf.
Can i swap these on my 2003 v70awd 2.5t? I realize i will require a tune, or mbc to see any real gains.
But if u were in my situation with the parts available, would the swap even be worth it? Would the downpipe on a 03 2.5 bolt to the older turbo?
This car is new to us, but runs great, pcv system is in good order, zero oil leaks and has decent power for a stock lpt. But i kind of want to mod this car a bit, the 01 xc it replaced stayed stock for the 6 years we had it. But this car shifts smooth and wants a mild tune atleast im thinking :)
Thanks in advance to anyone with an opinion on modding a lpt.
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
osman
Year and Model: 2002 c70 hardtop
Post by osman »
the downpipe from a LPT wont fit on the larger size turbo. You will have to custom build the downpipe.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
Japedo
Post by Japedo »
Okay, well i do have a downpipe from a 2.3 t5. I could cut and paste that into my existing exhaust.
But im not familiar with these lpt engines. Is the higher compression ratio that these engines have a limiting factor in how high they can be boosted?
Thanks
For
The heads up on the different exhaust!
osman
Post by osman »
The rods are the same as far as I know however I believe the cylinder walls might not be as thick as neccessary for the extra compression, probably need to change injectors, and exhaust as well as tune.
Brick Life
99 XC70 AWD LPT 115
Japedo
Post by Japedo »
Right on, ill do some more research. The 13g turbo it has currently adjusted to make 11 or 12 psi via a ecu tune, and bigger injectors may be all the tune i need. Just an extra 30 or 40 hp would make me smile :)
Thanks for the input osman
