warning chime!
ChaddGostas
Year and Model: 1996 850 glt
Post by ChaddGostas »
I tried using the home made flash code reader and activated my warning chime, and disabled my key fobs.
I disconnected the negative battery cable to try to get rid of this hideous dinger!
can anybody tell me how to get rid of this dinger and get my car back to before I poked around with the home made flash code tool. All I wanted was my mileage. :oops:
ChaddGostas
It appear my car alarm is not working either.
no fob.
constant chime
no little red light.
disconnected battery cable for 10 min
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I think your question was answered in the other thread but, if you didn't read it, check Fuse 15.
ChaddGostas
fuse 15 is good, at least is looks good in the dark. I will replace it, no matter what it looks like.
I will check the central locking fuse too.
I will check all the fuses associated with the problem areas.
food for thought, when the interior lights are turned off, <not on auto> or on, turned off, the chime goes away and the interior locking mechanism works, I can lock the doors from the inside.
when the lights above the mirror are turned on, or on auto, it constantly chimes and the lock switch is useless.
I will try to reprogram the fob's as I feel I did them injustice by failing at reprogramming them earlier.
I truly love this site and the fellow friends who are eager to lend out their knowledge.
Thank you Men! Thank you Women, if any are here helping :D
ChaddGostas
BOOM! PROBLEM SOLVED!
Ask me how....
I replaced the fuses associated with:
courtesy lamps,
central locking system,
diagnostics
ALL WORKS PERFECTLY NOW!!!!
pretty sure it was 15 that was the bad one too. ::::even though it looked fine in the dark::::
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
And...if you hate that stupid chime as much as I do...pull the blue relay under the dash.
'98 S70 T5
2016 Chevy Cruze Premier
ChaddGostas
I like the screw through the speaker method ;D
jblackburn
I like the boot heel into the pavement method, but that's just me. :)
'98 S70 T5
osman
Year and Model: 2002 c70 hardtop
Post by osman »
Go under the drivers kickpanel where the central locking and antitheft and door chime relays are. The blue one with the built in speaker is the offending relay. Pull it out and voila.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
