For Sale - 1999 Volvo S70 Base, Southern New Jersey
mtm3200
Year and Model: 99 V70XC
Post by mtm3200 »
I am selling a 1999 Volvo S70 Base with an automatic transmission. It is in overall good condition, runs well, and has been very reliable. The paint is in good shape and is glossy, although there are some chips and scratches which are mostly on the front from road debris etc. It currently has 275,xxx miles on the odometer but runs and drives like it has less. I have done all the oil changes since I acquired it in 2008 with Mobil-1 oil and OEM Mann filters. Everything on the car works. All power accessories are functional including all windows, locks, lights, heated seats, radio/CD player, and even the power antenna. The air conditioning works and blows cold and the heat works as it should. There are no warning lights on while the car is running (all the bulbs work). It has many new/newer parts that were installed since I acquired the car including but not not limited to: alternator, radiator, spark plugs, PCV, struts and mounts, control arms, outer tie rods, all four brake calipers with rotors and pads (front pads are Akebono and were replaced more recently than the rear). It does have some damage to the rear left from being run into by a motorcycle. Also, I am unsure of the age of the timing belt as I did not receive any maintenance records when I purchased the car and I have not changed it. I do not see any cracks in the belt when looking at it but it is most likely due for a change.
I am asking $2000 for the car.
Pictures: imgur.com/a/mq94i
mtm3200
Post by mtm3200 »
The car is still available.
