Severe Exhaust Drone with Free Flow Cat Downpipe
theblackanvil
- Year and Model: V70 2.5T 2004
Recently installed a Viva Performance 3" down pipe with a free flow cat (very similar to IPD) on my 2004 V70 and I am getting a very nasty exhaust drone from it at approx 2400 RPM's. Tried weighting it but that hasn't calmed it down much. Anybody with a similar install having exhaust drone issues? Thanks.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
How is the pipe resting on the front mounts?
The P2 exhaust system is supposed to rest on the mounts at the front to free the flex section and reduce that drone.
I just installed a DP on my 2004 V70R which is similar if not the same as your pipe and it has no drone.
theblackanvil
Jimmy57, thanks for the response. I'm not sure now. I will check. What type did you install?
theblackanvil
The downpipe hanger rods are in the bottom holes of the rubber mounts. The downpipe is very snug. I doubt that front mount does anything to help suspend that downpipe.
- 4056 Views
Last post by - Pete -
- 2393 Views
Last post by BlackBart
- 1791 Views
Last post by biohazrd76
- 6898 Views
Last post by xHeart
- 731 Views
Last post by sanfelice
