Hey all, long-time no post. Been busy with pilot school so I've been lurking mostly. Got a question about exhaust sound. A while back I had the resonator removed and a Magnaflow muffler put in place on the left side. Cat converter is still in. I actually really like the sounds it puts out. Not bad for a quick job at the muffler shop, but there is some loud droning on the highway. This leads me to a couple questions:
If I had the pipe after the cat split (Y) to go and add another muffler for the right side, would that increase, decrease, or not change the loudness?
Regardless of the solution above, what else could I do to tone down the volume a little? Would adding a glasspack or something post-cat but pre-mufflers make a difference?
Thank you exhaust experts!
Exhaust Question (Loudness)
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
FlyingVolvo
Le bump?
Sorry, maybe this should be moved to the "Performance, Tuning & Aftermarket" forum. Moderator please?
2023 V60 T8 PE
2023 V60 T8 PE
precopster
- Year and Model: Lots
- Been thanked: 128 times
I'm no exhaust expert but I would imagine with half the gas pressure alleviated from one of the pipes you should get a huge decrease in resonant sounds.
Two pipes at the rear will look great.
- 11 Replies
- 7611 Views
Last post by Sufbug
- 603 Views
Last post by bskeels
- 1370 Views
Last post by frperilla
- 917 Views
Last post by rspi
- 485 Views
Last post by hausmeister
