2005 S40 2.0D to scrap or not to scrap
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
mastac
Year and Model: S40, 2005
Post by mastac »
Hi all
Can somebody please give me some advice with what to do with my car. I had a problem with it in September 2012. The car would sometimes refuse to start when the engine was warm. After waiting a while it would start. One day the car cut out when driving and wouldn't start again. There was air in the fuel lines. I left the car alone for a few months but eventually got it working again with a hand priming pump. I've had it "working" again for a grand total of 2 days, although the warm starting issue is still there. Today I left work and started the car, I noticed it felt quite rough when idle, a lot rougher then usual. I got the car home then about 15 mins later went to go out again and it wouldn't start. I left it for a while and it still wouldn't start. Somebody on this forum told me the throttle body could be sticking shut causing the problem so I removed the throttle body and it is not sticking shut.
I then noticed there was air in the fuel lines again so I assume I have an air leak somewhere. I tried to get it going again with the hand pump to no avail. I know the car has a few problems and am wondering if it is worth me getting it fixed properly or scrapping it.
I had a diagnostic on the car and it came up with the following faults:
Code001: ECM-0 Glow plug relay.380 Faulty Signal
Code002: EGR control. 1335 Faulty Signal
Code003: ECM- Fuel injection. 1213 System driver faulty signal
Code004: ECM-0 EGR Control. 490 Signal too high
Code005: ECM-0 Fuel injection. 200 System driver signal missing
Code006: ECM-0 Generator. 625 Signal too low
Code007: ECM- Stop lamp. 1935 Stop lamp switch faulty signal
Code008: ECM - Communication. C326 Control module faulty signal
I paid nothing for the car, however I think I will end up spending a hell of a lot putting everything right. If anybody can let me know what these codes mean exactly and if you think it's worth putting right I would be grateful.
It's a 2005 2.0 SE with approx 160,000 on the clock.
Thanks
