oxygen sensor
sisterocean
- Year and Model: 2007 V70
Would a dirty oxygen sensor cause a random misfire cynider 4?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
No. Bad plug, wire, injector, or low compression.
sisterocean
Its been a problem for awhille. I have replaced plugs wires distributor cap rotor checked the injectors by switching 3 and 4. Sometimes check engine light is off for awhile but it always comes back. Confused
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
So no misfire on 3 when you switched injectors?
Time to run a compression test.
'98 S70 T5
2016 Chevy Cruze Premier
sisterocean
Ok I'll try that next Thanks for the tip
- 1323 Views
Last post by brant
- 22319 Views
Last post by loveMy850
- 810 Views
Last post by olfac87
- 15 Replies
- 2835 Views
Last post by deepsouth
- 13 Replies
- 5318 Views
Last post by puntmeister
