mbc or no?
BomTillington
- Year and Model: 2001 s40
i want to install an mbc but i have read alot of different things im planning on a 2.5 cat back exhaust with a highflow rear cat and a magnaflow muffler i only wanna run maybe 12 or 13 psi anybody have any advice?
I run an mbc (set at 14 pounds of boost) with a with a similar exhaust setup and I have had no problems. Just keep the boost reasonable unless you get a tune. Too much boost and not enough fuel makes for a bad day. Having said that, a boost gauge is your best friend when your setting your mbc. When used with some restraint it is a great bang for buck mod.
95 850 T5-R rip kit,18t,ipd strut brace,slotted rotors,cone filter with heat shield, boost controller and boost gauge,cat delete and high flow muffler,horns relocated
BomTillington
Thanks man any advice on a brand or anything like that i really appreciate the reply
- 2699 Views
Last post by matthew1
