Check engine light on, with following codes showing:
P2090 Exhaust camshaft reset valve; Signal too low or signal missing
P0245 Turbocharger (TC) control valve; Signal too low. Permanent fault
P0445 Evaporative emission system (EVAP) valve; Signal too low. Intermittent fault
P0448 Leak diagnostic unit, valve; Signal too low
P2401 ???
Car runs fine. 200 miles ago, I replaced an ignition coil. In doing so, I removed hose clamp holding turbo air delivery unit at the point where it runs into the radiator...just under the oil dipstick. I'm wondering if I banged something up while moving things around to get at the ignition coil?
Any assistance in tracking this down is greatly appreciated.
5 codes on '02 V70 2.4T
precopster
- Year and Model: Lots
- Been thanked: 128 times
It may be a good idea to go over all the areas you may have disturbed when you replaced the coil.
My money is on wiring that has no or little plastic conduit under the valve cover and is sending erratic signals to the car's ECU due to intermittent grounding with the valve cover.
How does the car's wiring look. Is the conduit all torn up or is it complete?
goldwagon
- Year and Model: V70 2002, 137K miles
I'll take the cover off and check for grounds and/or stripped insulation.
Conduit is in good shape; I'm the original owner and know the car pretty well.
I'll keep all posted. Any other ideas out there?
ICHASESURF
- Year and Model: 02 v70 2.4t
I have all the exact same codes!!!! I'm going in circles and I just did a rebuild...02 v70 2.4t....did you ever figure it out???
- RickHaleParker
- Been thanked: 980 times
On electronically controlled vehicles wiring and connector condition is critical.ICHASESURF wrote: 24 Feb 2020, 13:56 I have all the exact same codes!!!! I'm going in circles and I just did a rebuild...02 v70 2.4t....did you ever figure it out???
One cannot let it go like the old school electrical / mechanical controlled cars.
P2401 = Leak diagnostic unit, pump. Signal too high
Active
Past
Past
ICHASESURF
So it was the wiring loom insulation?
ICHASESURF
Any help is greatly appreciated...I'm needing to pass smog in California!
- RickHaleParker
Get the car scanned and list the DTCs you have. Autozone will do a scan for free.ICHASESURF wrote: 25 Feb 2020, 11:52 Any help is greatly appreciated...I'm needing to pass smog in California!
Active
Past
Past
ICHASESURF
Haha...yeah, ready Past that point...it's just odd you had every single code the same as I
......just wanted to know how you cleared all the codes!
ICHASESURF
It ses odd and didn't know if an isolated issue caused it all??
- 19 Replies
- 10372 Views
Last post by Barledge
- 1906 Views
- 6615 Views
- 1559 Views
Last post by SuperHerman
- 642 Views
