While waiting for a new (2nd warrantied) radiator to arrive I was driving about a month and a half ago and it just died in traffic. Had to tow it home and just stored it until I could get the radiator in (since I was fearful that it was a blown Head gasket)
So last week I finally got the radiator in (took my time and did it right) then got it diagnosed since it would only crank over and start but couldn't hold an idle. Mechanic checked the cyl. psi and the fuel psi @ the rail.
Cylinders were good @ 125-130 psi (No head gasket issue)
35 psi @ the @ the fuel rail Not good need 50-60 psi
So he thought it should either be the pump or the relay. He didn't have one to switch out so I searched the forum and found the jumper technique (paperclip from terminal 15-87) which allowed it to start more consistently, and finally idle at around 500RPM. Ran it for 30 -40 min. or so while I bled the radiator and replaced the water with coolant. Whew no leaks. Stoked!!!
Anyway so after about the first 15-20 min. shortly after the fan kicked on, the idle came up to about 750 which is good yet it was definitely running rough. So it starts much better now but still running rough. tried to take the jumper/paperclip out of the relay and put the relay back in and start it, yet with no success. I then put the jumper back in and she started right away and idles @ 750 no prob. yet still runs rough. Too rough to even drive. Ok so I know I need a new relay (RIGHT!!!)
Well I'm not 100% convinced so I am continuing to diagnose because I just don't know if that relay will restore the psi back to full when I receive it in the mail. I don't know if I should fully expect it to fix the issue. Is she running rough because the relay isn't installed, which should fully send the proper amount of electricity to the pump. Oh and BTW the pump is running and I can hear it whirr (continually I might add) while I am in the car with the door closed.
I read as much as I can find and found the fuel pressure regulator location as well as the rail has a pressure regulator also but not sure about the fuel line check valve (yet I've rule that out since it starts just fine now). I should get a fuel pressure gauge tester soon if not today.
If the relay doesn't fix it I am assuming the FPR is bad but I don't kow how to isolate that and diagnose it for my car. Your help is greatly appreciated in advance.
Thanks in advance, for reading my long post.
