Radio and car problem Topic is solved
myvolvo
my radio displays off, I have the code and I found that once displays off to put key in and leave ignition left on for 2 hours, but I didn't know if you leave the radio on or off? And are car is starting to jitter at low speeds. once it reaches higher speed stops..Don't know what it is? Please Help...
jjss70
- Year and Model: 99 s70 Turbo AWD
- Has thanked: 7 times
To: myvolvo From: jjss70: Try removing the negative cable at your battery, give it a minute to reset and replace the negative cable back on your battery. Turn your ignition switch on to the first indent or mark on your steering column at ignition switch and make sure nothing else is draining your battery down other than the digital readout of the word "OFF" by your radio. Wait 2 hours and when you see your radio after 2 hours it will be asking you for the code again. You only get three attempts at providing the correct code. Good Luck, jjss70.
- RickHaleParker
- Been thanked: 977 times
The post is 14 years old and the user is long gone. Last active:14 Oct 2009, 13:29
Active
Past
Past
jjss70
To: RickHaleParker, From: jjss70, In reference to "Radio and Car Problem". I'm sorry, I didn't even see the date for last active--only 10 years ago. Hey, while I have you here I want to thank you for all your time and effort and expertise on your many threads especially your Vida-Dice ones. Good Job and thanks again. I hope I can be of some help to someone else someday in the future. jjss70
- 4120 Views
Last post by 850TurboTurtle
- 11 Replies
- 10325 Views
Last post by JRL
- 723 Views
Last post by brandon570
- 788 Views
Last post by louis_m_c
- 700 Views
Last post by usinjin
