98 VOLVO C70 Map sensor location?
Braxxton401
Year and Model: 1998 c70
Post by Braxxton401 »
Hello everyone I drive a 1998 volvo c70 and was told by my mechanic and diagnostic tool that i need a new MAP sensor. I have purchased a new sensor but i have no idea of its location, looking at the sensor it looks like pretty simple fix one bolt and one plug. I have tried researching this on the web but i couldnt come accross anything that helps i found one stating that the sensor is located on the passenger side underneath the hood next to the washer fluid resevoir but in my car is not there.
please if anyone can help me out here i would greatly appreciate it . i dont want to bring my car back to my technician since i am still unemployeed thanks to our Modern day America lovely economy :roll: So anything that will save me some bucks i will try to execute myself. SO help please guys my car goes no where under boost.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
MAF? It's sometimes called a MAP too. He told you the wrong side. It attaches to the top half of the air box. It measures the volume of air and passes that to the ECU so that it can give the engine the correct air/fuel mix.
See posts about the mass airflow sensor.
Also -> Amazon link
orleec
Year and Model: 98 V70 GLT'ed
Post by orleec »
If you're referring to BARO sensor, here's a picture of it:
It's moot now because you bought a new one already but I was able to successfully clean it and the code did not come back after resetting it for thousands of miles now and after more than a couple of months. See link below:
https://www.matthewsvolvosite.com/forums ... 8&p=268164
Click me to save $150 on 94-98 Turbo Cooler Lines
* SOLD - 98S70 Blk/Blk T5M B&G/Bilstein, 17psiST, R-mani, 3"dp/obxExhaust, SASdel
* 98 White V70AT GLT'ed - LPT motor swapped
* 06S60 2.5T Blk/Blk - wife's DD
Braxxton401
Alright thank you guys for the help i really appreciate it. i replace the map or boro sensor, lmao i paid $139 for the sensor and my problem is still not solved . My car still wont go i try to punch it but it wont respond its like the car chokes , can this be my MAF that is defective my car idles kinda rough and has a slight hiccup problem when waiting at read lights any ideas ? also will a can of MAF cleaner do justice on my sensor and get it going again ? Guys also my gas mileage has decrease significantly when i bought the car my OBC will say 27mpg average now its at like 18mpg or less.
matthew1
Site Admin
Post by matthew1 »
orleec, good call! Braxxton401, can you get the code(s) that were triggered? Yes, you can try cleaning the MAF sensor. I've done it, as have many here.
Also -> Amazon link
