hi everyone
i have recently just bought a volvo 850 saloon and dont know much about volvos as this is my first 1 the battery went dead so i got a new 1 and stuck it in whenever i try starting it the car wont fire up but will carry on starting and on the clock theres a yellow arrow pointing up to the battery can any1 help me out here?
volvo 850 help Topic is solved
- Has thanked: 2865 times
- Been thanked: 1332 times
What year is your 850?
vicney
had the same problem, check the wire (14 gauge) that is attached to the possitive side of the battery. make sure is tight!!!!!!!
vicney i checked the battery and even put a brand new battery in there but what i dont understand is, i tryed starting it but on the dash the lights keep flashing something is killing the battery so i think it is something to do with the wires around the battery can any1 help please?
Okay, I maybe repeating what some people said. First clean off all contact areas on both terminal (disconnect the battery first) w/ a wire brush. And tighten the connection (do not skip this step, I learned a expensive lesson because of this on my old car). Check the wiring for any shorts or damage near the battery.
It seems to me that there is a short a high drain on the battery. I would turn off all equipment and start the car. If it still does the same, then you should have your starter and alternator checked out (Autozone does this free, if you can get your car to them...).
1998 Volvo S70 T5 Auto
1995 Volvo 850 GLT <- RIP
mate iv disconnected the battery and put in a new 1 but its still the same it wont start upkelvin6 wrote:Okay, I maybe repeating what some people said. First clean off all contact areas on both terminal (disconnect the battery first) w/ a wire brush. And tighten the connection (do not skip this step, I learned a expensive lesson because of this on my old car). Check the wiring for any shorts or damage near the battery.
- 1371 Views
Last post by CEBirnley
- 2028 Views
Last post by darylrobert
- 1556 Views
Last post by Craigd2599
- 27 Replies
- 2680 Views
- 2193 Views
Last post by Sommerfeldt
