Hey All,
The check engine light on my 1998 S70 has been on for over 4 years now and my mechanic (and I) have determined from the code that it is a faulty O2 sensor. I have replaced both the forward and rear sensors on two different occasions but the light comes back on. My mechanic thinks that it could be faulty wiring. I'm still getting good mileage (20+ city/27+ hiway) so I've just lived with it. Recently, though I talked with another mechanic that told me that there are actually FOUR O2 sensors - two forward/two rear. IS that true? if so, that would explain a lot. Otherwise, does anyone else have a clue what would cause the O2 sensors to code that they are not functioning?
Thanks and have a great day!
Steve
Are there more than two O2 sensors on S70?
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
I'm interested to see what comes of this. I've been looking at new catalytic converters for my 98 V70 Turbo and a lot I've seen show three. I've not looked all that closely at my exhaust but my monitoring tool seems to see only 2.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
There are only two sensors on the car. One before and one after the catalytic converter. I am no technician but If you could post the specific codes that are present I am sure someone on this board can help better diagnose this problem in detail and help get to the root cause.
1998 NA S-70 150,000 mi
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
There are two total. Period. The T6 has two banks with a total of four sensors, that might be what the second mechanic
You may find that vacuum or small exhaust leak is causing the codes. Post the specific code #'s if you can. Without them it's hard to help.
**Rant warning**
It still astonishes me how many "professionals" pull some codes and swap out sensors without looking at live data, freeze frames for doing any actual troubleshooting.
**Rant warning**
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Go do this to that guy. He has no idea what he's talking about.Recently, though I talked with another mechanic that told me that there are actually FOUR O2 sensors - two forward/two rear. IS that true? if so, that would explain a lot. Otherwise, does anyone else have a clue what would cause the O2 sensors to code that they are not functioning?
Also, what code are you getting? Most often, O2 sensor errors on these cars are related to vacuum or air leaks.
'98 S70 T5
2016 Chevy Cruze Premier
Thanks everyone...and jblackburn, if I ever see this guy again, I'll find the nearest salmon and give him a good slap. Funny stuff! I don't have a code reader but the next time I get it, I'll post the codes. Thanks all!
And as Phil says in Groundhog Day - "Don't drive angry"
jblackburn
Good man.jblackburn, if I ever see this guy again, I'll find the nearest salmon and give him a good slap
'98 S70 T5
- 388 Views
- 2250 Views
Last post by sleddriver
- 622 Views
- 2179 Views
- 30 Replies
- 6262 Views
