While on the road i was hearing an odd sound at my rear nearside tire. I decided to take a look and this is what i found. Two quite large tennis balls along the wall of my tire. Good thing i checked. I'll obviously get a new tire asap. I wouldn't mind but its a Bridgestone tire with about 15k miles on it.
How and why does this happen?
Tennis balls in tire wall.
Faheyk1981
- Year and Model: Volvo V70 1999
JDS60R
- Been thanked: 3 times
Not sure from the picture but it looks like some dry rot in the rubber. Mostly these lumps are caused by a structural failure on the tire either from hitting something (curb/pot hole) or just poor manufacturing.
Retired
- Has thanked: 2856 times
- Been thanked: 1332 times
+1, those small cracks mean unhealthy or old rubber.
LASteve
- Year and Model: 2015 V60 T5 E-Drive
You should be able to take it back to any Firestone shop and have it replaced. Most of their tires have a manufacturers warranty which covers this sort of fault.
Current Sled: 2015 V60 T5 E-Drive
Volvos I used to own:
02 V70XC
99 V70XC
97 855 NA
87 245 DL
02 V70XC
99 V70XC
97 855 NA
87 245 DL
nitehawk55
- Year and Model: S70 T5 1998
Running a tire flat or hitting curbs or pot holes can cause this too .
Faheyk1981
From thinking back on it i did hit a massive pot hole recently and when i checked the tyre pressure it was about 20psi. So hitting the pot hole with low tyre pressure looks to have done it.
Thanks all!
Kevin
Thanks all!
Kevin
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Tubeless tires effectively have an innertube as the inner layer of tire. If that layer gets bruised and has a breach it will leak through the carcass and be retained by the outer layer of tire. Since the outer layer is not not cloth reinforced it inflates like a balloon. There is enough rubber vulcanized through the cloth layers that the breach on the inside layer is localized. I have seen these ballooned spots grow and look like sausages. I have also seen them stay the same size and the tire wore out with the ballooned spot, though a small spot, still the same size.
DO not expect warranty. It would be very unlikely that the tire would not show impact damage when dismounted and spread on a tire patching spreader.
- regent
- Has thanked: 2 times
- Been thanked: 12 times
I have no clue how big the potholes in Ireland are but you definitely have a much bigger problem: Your car seems to be attracting those Jumbo Mosquitoes...i did hit a massive pot hole recently
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 303 Views
- 1029 Views
Last post by FLXC90
- 5983 Views
Last post by jrbettis
- 685 Views
Last post by brando_calrissian
- 3216 Views
