DIY: 1998 Volvo S70 GLT Parking Brake Tips/Tricks
This topic is in the MVS Volvo Repair Database » DIY 1998 Volvo S70 Parking Brake Tips/Tricks
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- Parking Brake info is scattered throughout forums, so I will try to put it in 1 place to consolidate the important tricks of the trade.
- Some good links are below, please read them:
E-brake doesn't work...see post by “Ozark Lee”:
https://www.matthewsvolvosite.com/forums ... php?t=8187
DIY: 98 V70 Brake Hydraulic Overhaul (Hoses, Seals, Parking)…by ”cn90”:
https://www.matthewsvolvosite.com/forums ... hp?t=37721
850 Ebrake cable replacement: How to by “Pauloil”:
https://www.matthewsvolvosite.com/forums ... hp?t=39200
I have 2 problems at 150K:
- Brake Shoe friction material fell off, parking brake was useless.
- Parking Brake Cables were somewhat seized at the rear areas (from cracked areas), and since replacing the cables is a PITA, I elected to save them, read on for the tricks! BTW, each cable is $50, so I saved $100.
Online vendors:
Rear Rotor by BALO: $25/each x 2.
Rear Parking Brake Shoes by TEXTAR: $35 for set of 4 shoes.
Volvo Dealer:
Big Spring...PN 1273836 x2; $6/each.
Small Spring...PN 3546028 x2; $5/each.
For these springs, stick to Volvo OEM and nothing else, unless you want to do the work twice.
---> Retaining clips...PN 9157979 x4 (No need for these).
BRIEF PROCEDURE:
This DIY is designed to supplement the above DIYs, so I will be brief.
Wear Googles when removing/installing springs!
1. Study the Parking Brake Anatomy:
2. Rear End on Jack Stands, safety first! Remove the 13-mm bolts and place brake caliper on a bucket (inverted). Remove the 10-mm nut that holds the rotor in place. Release the pressure by loosening the star wheel adjuster (see below for info, use flash light and small screwdriver), then remove rotor.
3. Once old shoes/springs are removed, take time to free up the seized cable. Oil/Grease the cable entrance (where the cable enters the hub):
4. Grease the following items:
- Adjuster
- Expander/Cable area as mentioned above.
- Where the brake shoes meet the adjuster and expander areas.
- Just make sure no grease is on the friction surface.
- Installation note: For adjuster:
* RIGHT side: star wheel faces REAR.
* LEFT side: star wheel faces FRONT.
This way when you adjust the star whell: UP is tighten and DOWN is loosen.
5. The special brake pliers that I have ---> useless!!!
- I used long screwdriver and pick tool or pair of right-angle pliers to install new springs:
---> BIG Spring first
---> SMALL Spring later.
6. How to save the Cables:
- The RIGHT side: 2 crack areas. The rubber sheathing cracked but the metal sheathing was still fine, so I bend the cracked areas a bit, add some WD-40, then 1-2 drops of oil. Repeat the process 10x to allow the oil to soak inside the Cable.
- Tug on the cable a bit, you will see the Expander moves in and out. This is a good sign that the Cable can be saved.
- The LEFT side: only 1 cracked area.
- Again, Oil/grease the area.
- Cover all cracks with 1/2-inch heater hose and zip ties.
- Just slice the heater hose lengthwise and the “opened” area (the part that you spliced) faces downward: this way any water that enters the hose area can drain.
- Since both cables were somewhat seized, I had to pull the Lever (in the cabin) some 20x to free them. Then I tug the cable at the cracked areas a few times. Finally they both freed up, thanks God I saved $100!
7. Installation Note:
- During removal, the force of pulling off the rotors will pull the Retaining Clips outward a bit. Just push them back in with a screwdriver so they hug the new shoes properly.
- Grease the parts as mentioned above.
- I applied a small amount of Anti-squeal compound on the caliper piston areas. This solved my brake squeal noise!
8. How to adjust the PB Lever:
- See other DIY threads above for info.
- Basically release PB Lever.
- Tighten the star wheel until the rotor stops turning, then back off a few 3-4 notches: use flash light and small screwdriver. The rotor should spin with a slight drag, which is normal.
- Once done, make sure the PB Lever does not move more than 7 clicks once engaged. You may need to adjust the PB Lever inside the cabin (Torx key).
9. Road test and brake shoes bedding:
- Do the "Brake bedding" for the Parking Brake. I think it is a few stops using Parking Brake at speed of 30 mph or so.
- Find an empty stretch of the road to do this "bedding" thingy!
That is it boys and girls!
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Very nice and thank you for gathering useful info all into one thread.
Suggestion for Step 3: Once you have the rear brake assembly apart, clean it all up real well. Go from coarse to fine so wire brush on the hub surfaces and any rust spots, then give all surfaces a shot of brake cleaner, get a toothbrush on the ABS sensor cogs and the sensors themselves, another shot of brake cleaner and some paper towels or shop rags to wipe it up. Once everything is clean, start assembly with grease for the cable etc.
Bedding these shoes at 30 mph sounds a bit overkill, they are only designed to hold a stationary vehicle, I might do like 15 mph or something. Just a thought.
FYI right now there are parking brake shoes on closeout at FCP for $20. They are Scan-Tech brand but parking brake shoes are a no-stress item. I have installed the Scan-Crap shoes on my car and they haven't fallen apart yet. Since, as cn90 noted and I have also experienced, even the OEM ones fall apart eventually, I am comfortable with the budget item in this case.
filipe martinho
Year and Model: V70 GLT 1997
Post by filipe martinho »
Hi,someone can´t tell me, :idea: how to replace the rear brake expander,some photos or videos how to do it any :idea:
Filipe Martinho
QuirkySwede
Year and Model: 1998 S70 GLT
Been thanked: 12 times
Post by QuirkySwede »
Might also check
DIY: Parking Brake Failure Inspection ('98 S70 as ref')
regarding other failures and how to address.
Sample image:
