new to volvo, but have no fear. Working on a 97 850 wagon for my 17 year old daughter, 1st car. have some issues and looking for advice.
-Engine code telling me the engine temp is too low and I think it is effecting the fuel mileage, I am replacing the thermostat, any other advice for this issue??
- the ac/heat system is not functioning, it is flashing on start up but none functional after that. Wondering if I replace the whole control unit if this could fix the problem?
1997 850 glt woes
the 1 buchanan
- Year and Model: 1997 850 GLT
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Change the coolant temp sensor and thermostat.Engine code telling me the engine temp is too low and I think it is effecting the fuel mileage, I am replacing the thermostat, any other advice for this issue??
As far as the HVAC unit...troubleshoot first...the flashing lights could mean a number of things. Does the fan work on the slider setting? Is it maintaining temperature if the fan is set manually?
'98 S70 T5
2016 Chevy Cruze Premier
- Been thanked: 504 times
1+,
1. Tstat, stick to Wahler or Volvo brand, about $18 with O-ring
Replace the ECT, use only Volvo OEM for ECT $40:
https://www.matthewsvolvosite.com/forums ... hp?t=52203
2. HVAC Unit, likely ECC unit,
Search forum for some diode acting up.
Try these links:
https://www.matthewsvolvosite.com/forums ... =1&t=27239
http://www.volvoclub.org.uk/tech/servic ... m-Auto.pdf
Try these links:
- 1874 Views
Last post by precopster
- 12 Replies
- 2456 Views
Last post by zeke1256
- 25 Replies
- 3192 Views
- 26 Replies
- 3815 Views
Last post by Cookeh
- 19 Replies
- 3124 Views
