Here's an essay on that question. I guess I've been changing mine a bit more than necessary.
http://www.edmunds.com/car-care/stop-ch ... 58&msite=w
Debate: How often should you change your oil?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I do ~8000 on the Chevy (using Mobil-1) and did around 5-6000 on the S70 w/ Mobil-1. The S70 was driven much harder.
Our Toyota specifies 10,000-mile changes; though I'll probably not let it go past 8,000 either.
With that said, these 5-cylinders benefit significantly from using a synthetic oil that will not sludge up.
'98 S70 T5
2016 Chevy Cruze Premier
JRL
- Year and Model: Several
- Been thanked: 16 times
No, you probably haven't.
While I agree that MOST cars do not need these constant oil changes but this really does not apply to the 5 cyl Volvo.
You need to remember that this basic engine design has been around since 1992 with NO CHANGES to the oiling system.
If your oil becomes too dirty and if you don't constantly run it at high speeds (most of us don't), it WILL sludge up.
(It's the ridiculous PCV/breather, oil separating system these engines have).
If you follow a 10K oil change regiment, I will guarantee you that this engine will be thoroughly clogged up by 70,000 miles! Heck 7500 miles is too long with dino oil.
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
Leaving the oil too long can also cause the PCV sump return path to block with carbon, the only effective way to clear this is by removing the sump and clearing the carbon build up from the base of the return duct in the sump, costly, messy and avoidable 5K between changes - Mike
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I completely agree with Jim on this. For this reason I've been changing the oil between 3500 - 4000 miles on my 850 for the last 200k. And surprisingly (or not so) the PCV system has not been clogged even after 165k when I did it for the first time. It's when you get sloppy with the oil changes you get in trouble, that's the main cause in my opinion.JRL wrote:No, you probably haven't.
Needles to say, I'm doing the same with the XC.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
I run M1 0W40 for 10k miles between changes. I have 2 98 S70 N/A's. one has 186k and the other has 408k (yes, 408k miles). Never an engine problem with either one. People change their oil too frequently in my opinion.
2008 XC90 3.2L - 134k
2006 Ford F150 4x4 124K
Sold 98 S70 N.A.@418K-still ran great!
jblackburn
WOW. But I take it you drive an awful lot every day? If so, extended O.C. intervals make a lot of sense. Problems arise when cars are used for short trips where the oil is not allowed to ever warm to full operating temp and accumulates a lot of water.bguzz wrote:I run M1 0W40 for 10k miles between changes. I have 2 98 S70 N/A's. one has 186k and the other has 408k (yes, 408k miles). Never an engine problem with either one. People change their oil too frequently in my opinion.
'98 S70 T5
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
The car I now have had oil changes every 3,000 miles before I got it. The dip stick wasn't smoking so I took my time with getting the PCV replaced. A few months after getting the car I got around to changing it and the system was clogged pretty bad. I had to find the EGR hole in the manifold and the block passages were 90% and 40% blocked. The car had about 193,000 when I replaced it.
I'm now running 10W-30 Mobile 1 high mileage oil and plan to replace the PCV every 50,000 until I see a reason not to. I'm changing the oil every 5,000 but may extend that after sending a sample to Blackstone.
Nophix
- Year and Model: 1998 Volvo V70 T5M
I do about 10-12k on synth, but I get on the interstate 1 mile from home and off right in front of work. 70 miles each way with cruise locked at 72.
Oil has always been clean as a whistle and I've had it tested just to be sure. Car has 250k on it.
Unfortunately, it's sitting now waiting for a new owner, or me to have time to take care of some small issues (radiator and wheel bearing).
jblackburn wrote:WOW. But I take it you drive an awful lot every day? If so, extended O.C. intervals make a lot of sense. Problems arise when cars are used for short trips where the oil is not allowed to ever warm to full operating temp and accumulates a lot of water.bguzz wrote:I run M1 0W40 for 10k miles between changes. I have 2 98 S70 N/A's. one has 186k and the other has 408k (yes, 408k miles). Never an engine problem with either one. People change their oil too frequently in my opinion.
True for the 408k one, the others my wife's and she does lots of 20 minutes drives. Haven't noticed any issues, but maybe the oil gets fully warmed up by that time. I probably would do less frequent if I live in the city.
