Did you know? 🤔
B4 servo
2001 - 2007 XC-70
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 47 times
United States of America
vtl
Re: B4 servo
Post by vtl » Mon Aug 12, 2019 8:05 am
Katten wrote: ↑
Mon Aug 12, 2019 7:32 am
Is there any way of knowing how much longer the piston needs to be? Or to know if it needs to be longer at all. My piston has two bands running on the top cone.
Yes, you can check the piston travel, and it should be within the specified range 5.76-6.76 mm (mentioned on the second photo I posted).
Unfortunately, it is not really possible to measure the travel with transmission sitting in engine bay, so 0.5mm for every thousand miles is a good guesstimate ;)
I welded more after taking the picture, the pin is 1 mm longer now. But I may try to take one washer out first and see how it goes.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
Katten
Year and Model: S80 2002
Has thanked: 0
Sweden
Katten
Re: B4 servo
Post by Katten » Mon Aug 12, 2019 10:07 am
I just got a piston and cover from the junkyard for $5.
Same type as my car, two lines and same length. Might use one of the to weld and experiment :). Does this piston have anything to do with the 3-4 gear change also?
vtl
vtl
Re: B4 servo
Post by vtl » Mon Aug 12, 2019 10:16 am
Katten wrote: ↑
Yes. The 4th gear is engaged then the 3d is disengaged. When the piston can't move backwards fast enough (because it has to push more ATF in the same amount of time) you'll feel something like short slow down/power loss.
Katten
Has thanked: 0
Sweden
Katten
Re: B4 servo
Post by Katten » Mon Aug 12, 2019 10:26 am
vtl wrote: ↑
Katten wrote: ↑
Okay, i might have screwed up abit. When I took out my pison i polished it since it had lots of ware on one side and also the part where the o-ring goes on the piston was jaggered/scoored on a few places. Polished that too. Also took a 2000 grit sandpaper and took out som wear on the cylinder walls where the piston travels. Could feel a spot where the aluminium felt different. That might have been a bit mistake :(. Still have the 2-3 flare at low speed when hot, but now also have a bumb/hard shift fram 3-4 some times. Also when hot. That bumb was bot there before. Need to add that I did a adaption of the Controle Module and had to drive like 2 hours and still could not complete 2-1 downshift or N-D garage shift but the rest flashed the triangle :). Well I might try Lucas Transmission fix before anything else, what I have read it wont hurt anything.
vtl
vtl
Re: B4 servo
Post by vtl » Wed Aug 14, 2019 6:09 am
Katten wrote: ↑
Measure piston travel. Or just weld 0.5-1 mm :)
Katten
Has thanked: 0
Sweden
Katten
Re: B4 servo
Post by Katten » Thu Aug 15, 2019 4:09 am
I might weld the replacement piston and test once I get the time :). First I will add Lucas Transmission Fix and see what happens. If it does not fix anything the piston is the next item I will test :). If I get the transmission sorted an oil cooler and filter will be added too! :)
Katten
Has thanked: 0
Sweden
Katten
Re: B4 servo
Post by Katten » Tue Aug 27, 2019 4:12 am
After Lucas Transmission Fix car still flares when shifting 2-3 and jolts abit from 3-4. Only when warm tho. I guess solenoids need cleaning or replacing, also B4 servo piston might have some issues but I will run like this for now.
