MAF cleaning for 1999 V70 T5 2.3 HP Turbo
Has thanked: 1611 times
Been thanked: 4072 times
Thread to document and picture my cleaning of Mass Air Flow Sensor on my T5
Thinly veiled attempt to get some respect (R Dangerfield) on this forum.... :lol:
One special tool needed - Volvo part 31415926535 - light green turbo hose fixture ( see pictures)
Tools and cleaner required
Remove connector from MAF
Remove 2 Torx Screws from MAF to Air cleaner housing
Remove MAF and Air cleaner housing from car
Leaving behind MAF connected to turbo hose (note large O-ring on MAF may stay in Air cleaner
The MAF was really tight in the turbo hose and tough to pull on.
Loosen hose clamp (screwdriver) and then secure turbo pipe with special Volvo tool (must be green) and pull/wiggle/rock MAF out of turbo hose
...and clean with CRC spray cleaner - all around the sensor and wires, catching junk and solvent onto paper towel below.
tridents65
Year and Model: 1995 850, 2006 S-804
Post by tridents65 »
Any directions to test one (not just unpluging it) with a multi tester would be greatly appreciated. Pictures work great!
1965 Chevy C-10
1954 Chevy BelAir
1949 Plymouth P-18
1995 Volvo 850
2006 Volvo S80
2004 Grand Prix
rugbygrrl_15
Year and Model: 98 S70 Base
Has thanked: 6 times
Post by rugbygrrl_15 »
Hi,
I have a 1998 S70 manual transmission. I want to thank you very very much for posting such great photo's and instructions. I need to smog check my car to register it, but they won't run a smog check unless the check engine light is off. Yadda yaddah
I can't afford to bring my car to the mechanic right now, so I bought a cheap-o code reader, and decided to DIY. Short story, $63 dollars later (cost of scanner and MAF cleaner) the check engine light is off.
Thank you everyone
S
Special tool for MAF REMOVAL from snorkel on turbo P80s
Pictures above
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
abscate wrote: 07 Mar 2013, 08:20 The MAF was really tight in the turbo hose and tough to pull on.
Did you notice any kind of difference after cleaning the MAF?
BMW 540i 2002
S70 Base 2000
Of course not. They only get dirty if you use oiled filters or really pathologically dirty air filters
This one goes way back to 2013 when I was a Volvo NooB and trying to solve my loose induction turbo hose by throwing parts at it rather than analyzing the failure
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Using a proper TAMPER-PROOF TORX BIT to remove the sensor from the housing saves having to yank the MAF out of the hose. :)
