Timing belt pulley install question
bags519
Year and Model: 2000 V70 XC
Post by bags519 »
Is it possible to replace the pulley without having to move the belt excetera?
Everything else was replaced about 10,000 miles ago by the previous owner by mechanic but he did not replace the pulley
Thanks for your help in advance
Current Vehicles
2000 V70 XC (New Project)
2000 S70 SE 2.4 Manual (Daughter)
2004 VW Jetta GLS (Daughter #2)
1997 Chevy K1500 (Work)
2002 Chevy Silverado (Son)
2006 Audi A8
1985 Yamaha Venture Royale
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The tensioner will need to be released and the the belt slackened to get the roller off. Which one are you changing? I would be inclined to also change the tensioner if it was not changed along with the last belt and that is not the pulley you are talking about.
You will need to go through the CVVT pre-load procedure and have things lined up to the timing marks before you try to remove anything as a precaution.
bags519
Post by bags519 »
I was planning on both the roller and tensioner if I was in there.
I'm assuming cams will need to be locked.. I've done twenty timing belts through the years. But this is my first with cvvt.
I will look over the tutorials.
Thanks
Current Vehicles
2006 Audi A8
Post by Ozark Lee »
The CVVT procedure is pretty easy so long as the CVVT hub is not removed from the camshaft. Rotate the engine by hand, Clockwise) to the timing marks. Continue clockwise an additional 90 degrees.
Rotate the engine back (Counterclockwise) to the marks again. Replace whatever you are replacing and then align the CVVT outer sprocket to the timing mark as the belt goes on.
The cam locker might actually be an impediment but that is your call.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
The cam tool is totally unnecessary. If you take the plugs out, you can move the crankshaft by hand in very small increments to align the marks :wink: If you are gentle, the sprockets will not have to move more than 1/2 a tooth if at all during the replacement steps.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
bags519
Post by bags519 »
Well that sounds a lot more familiar.
So the extra 90 degrees and back and realignment gets the cvvt hub where it should be.
Thanks for the clarification on that.
Sounds like maybe an hour to a hour and a half?
Thanks guys.
Current Vehicles
2006 Audi A8
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
Don't lock the cams. Do what Lee said and go forward then back. I botched my last t-belt job on a vvt motor by locking them. Out of about 8 t-belt jobs, that was the first and last time I use that locking tool.
It shouldn't take long because you won't have to remove the t-belt or the belt guard at the bottom of the crank.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
regent
Post by regent »
And you can always keep the belt snug with some elastic (or even secure it to the sprockets with tywraps), count the number of cogs between sprockets, etc.
Once you're done, regardless of your hurry and meticulous accuracy, before you even think about the ignition key, always verify that the timing train is clear of loose tools and leftover parts, then rotate the crankshaft a few revs by hand then check, check and then double check the marks - don't ask me how I know :shock:
2015 BMW 335i
bags519
Post by bags519 »
I like the zip tie idea a lot, I can't believe that's the first time I saw that mentioned. Usually mark with nail polish or white out.
Current Vehicles
2006 Audi A8
bags519
Post by bags519 »
On the same note.. when it comes to parts.. I know everybody says stick with the blue box... but the local dealer wants $214 for the timing kit.
With weather being nice this weekend and my son being available (always like to involve him in my mechanical hobby)
My local choices are a dayco kit with the tensioner and pulley for $62 or from the dealer... I am not cheap but the car has 195k on it and I would think the dayco parts should last at least 40-50k.
Thoughts? Anybody use the dayco with good or not good results?
Current Vehicles
2006 Audi A8
