gear selector switch getting stuck, will not release.
wheeler000
- Year and Model: s70, 2000
every now and then in my 2000 S70 the gear selector switch will not release unless I give it a good vertical whack. what to do what to do?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Take both hands and push the knob down more. Happened to me once. It had just come un-clipped a bit.
Does the brake pedal shift interlock usually work, or do you have to use the "shiftlock override" button?
'98 S70 T5
2016 Chevy Cruze Premier
wheeler000
have not had to use the override button. it's been okay to give it a whack. I will need more time to diagnose it, it just started happening. you never know, if I keep beating on it maybe I'll get a new transmission out of a deal. insert text style
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
Check the brake light switch located on the bracket above the brake pedal, if this has worked loose it will not only give you intermittant brake lights (dangerous) it will prevent the gear selector from moving away from park as the switch is used to energise the gear selector release solenoid - Mike
wheeler000
does not get stuck in park. does not get stuck anywhere, just the little button on the knob gets stuck.
mikealder
You mean the trigger is stcking in? if so best fix that I have found for this is to release the leather gaitor by turning the top part through 45 degrees and pull down, the leather part should drop away from the selector know, next grab the handle and pull it up and off the gear stick, there is nothing to take to bits just pull it straight off, now you can spray a PTFE based lube inside the gear selector knob working the trigger at the same time, once complete wipe off any excess fluid and refit to the car.
DO NOT use WD40 as this will gumm up the trigger even worse after a few weeks, I use a spray called GT85 which is PTFE based, since doing this to both my V70 and V40 about four months ago beither car has suffered with a stuck trigger - Mike
wheeler000
Thank you, I will try it.
Thanks for this post, Mike. My 1999 v70, took me 90 seconds to fix an every-drive annoyance. With the ignition on (but don't start the engine), move the gear shift back to Low. This provides a good angle for pulling up hard on the shifter to remove it. With the shifter off, it's easy to inspect the trigger. At this point the internal spring will keep it in 'depressed' mode--as if you're pressing it to shift. Put a flat-head screw-driver up the shaft, and you can move the button to its open and shut position. If the bottom is cracked such that it doesn't hold the steel pin that keeps it in alignment while the button moves, you might best replace the part. About $24 online at iPD. Mine was cracked but holding on, so I sprayed some silicon spray up the inside of the shaft, then worked the button back and forth a lot. Be prepared with paper or cloth towel to wipe away the excess lubricant. Re-install the shifter by sliding it straight down on the gear shift shaft. Then work the button a lot more and wipe up extra lubricant. Re-position the boot and you should be all set. I saw an immediate and dramatic change to 'works like new' status.
JRL
- Year and Model: Several
- Been thanked: 16 times
Shifter button is probably cracked
IPD sells a replacement button kit
The last 8 or so of these cars I have bought ALL have had a broken button and when it gets too bad it sticks.
(A poor Volvo design as usual)
Feel the bottom of the button with your finger tips, if it's not 100% smooth it's cracked
Sounds like a bad shifter button on the handle itself. go to the junkyard and pull one or order one online, whichever is faster. this happend to me once. those things just go bad over time. the pins on the inside of the button has failed. you need a new shifter knob.
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
- 4734 Views
Last post by herbakis
- 2275 Views
Last post by cohomology
- 1148 Views
Last post by bmncw
- 1109 Views
Last post by Eat-Fish+2
- 2182 Views
Last post by fields 100
