CVVT issues after belt replacement
00wagonV70
Year and Model: 2000
Post by 00wagonV70 »
Long story sort. 2000 V70 Wagon, 2.4L B5244S engine. Just replaced TB & tensioner/ idler even with my setup to keep things "tied down" the intake cam managed to jump out of time. Had someone else working with me who ended up rotating both cam pulleys. I lined up crank mark, cam marks, TDC on #1.... did it again to make sure everything lined up.. rotated the engine by hand several times by hand to make sure no valves were hitting.... enging turns.. but doesnt really "crank" and didnt even seem to want to fire. it may not be gatting spark from due to one of the cam/ crank sensors being off.. likely due to the fact that the position is not correct. the real question is, how to I get the bottom end of this engine in sync with the valvetrain. ive done this kind of work before, just not on 'these' types of cars. any rational advice is appreicated, and if I need to elaborate please specicy.
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
Before you pulled the original belt off did you go clockwise an additional 90 degrees then counterclockwise back 90?
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
00wagonV70
No, i did not do that.
00wagonV70
i am afraid to ask if at this point i should get everything lined up an then go bak 90deg before i put everything back. theres got to be a way to get these thing lined up correctlyl fom this point. NO puleys came off and the CVVT hub was never adjusted. all timing marks lines up perfect before removal. Im not quite to the point of throwing my hands in the air, so maybe before I hit that point one of you volvo enthusiasts can lend me a hand!
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The CVVT side sprocket floats on its mounting bolts. The procedure, which you can do now to correct the pre-load, is as follows:
Set the timing on the crankshaft and camshafts to the timing marks.
Continue clockwise an additional 90 degrees.
Rotate back 90 degrees counterclockwise to the marks.
Remove the timing belt from the camshaft sprockets and then re-install it, lining up the CVVT sprocket to the marks as the belt goes back on.
From there adjust the tensioner and you should be good to go. I normally run the engine for a few minutes and then touch up the tensioner to get the indicator in the window again.
00wagonV70
I dont suppose I can ask for a bit more detail?
Post by Ozark Lee »
This will give you a headache but you asked for it.
99 XC Timing Belt Replacement.pdf
(1.32 MiB) Downloaded 203 times
That is for a turbo with the CVVT on the exhaust camshaft. The NA models have the CVVT on the intake camshaft but the procedure is the same.
00wagonV70
its the NA motor with the cvvt on the intake cam. i "tried" your procedure this afternoon, and i feel like you know exactly what issue Im having. I just need move elaboration in the whole process
00wagonV70
to clarify... i am at the point where i am not sure what position the ex an int cams are at (other than the notched marking on the gear tooth) with relation to the crankshaft (double maked gear teeth to notches in block). I turned everything by hand to the positions inticated by marks, then advanced the cvvt cam 1/4 turn, and back to aligned mark. i then refit the tbelt, cranked by hand several rotations. the marks held, tension is ok.. still in a no start condition. hoping i can get this sorted soon
bags519
Year and Model: 2000 V70 XC
Post by bags519 »
I can't upload a pdf via my phone but have factory instructions I found here. Give me an email and I'll send em over.
Current Vehicles
2000 V70 XC (New Project)
2000 S70 SE 2.4 Manual (Daughter)
2004 VW Jetta GLS (Daughter #2)
1997 Chevy K1500 (Work)
2002 Chevy Silverado (Son)
2006 Audi A8
1985 Yamaha Venture Royale
