Traction control light come on when you turn?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Dempsy
Year and Model: 2003 XC70, 200k KM
Volvo Repair Database Traction control light come on when you turn?
Post by Dempsy »
I have been chasing my traction control light around for months checking bearings, wiring, sensors, abs module.......etc
So I called the company that I bought my abs module off and the first thing he said was to check the stater ring on the axle to see if it has a small crack. So I took the abs sensor out of the hub of the front wheel and turned the axle so I could check each tooth for a crack and sure enough the ring had completely broke and was hitting the sensor, so I replaced the whole axle and there you have it. Problem solved! I hope this saves anyone the stress of chasing this down.
My abs module would click when I turned so it was coming on and off trying to work but there was no wheel spin.
cheers
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1240 times
Post by matthew1 »
Thanks Dempsy. I'll put this in the Repair Database so its more available than otherwise.
This is one I've never read about!
Also -> Amazon link
nzvlnr
Year and Model: 1999 s70t5
Post by nzvlnr »
Was there a clicking noise when you put the car in drive? My car has been doing this for years ....... I am having issues with my ABS/BRAKE and traction lights and my ABS module has bee replaced and tested
Dempsy wrote:I have been chasing my traction control light around for months checking bearings, wiring, sensors, abs module.......etc
cheers
nzvlnr
Post by nzvlnr »
bump.....feedback?
