Heard you can check crankcase pressure using the T on a s70 GLT.
Does anyone have a writeup or experience using this method. If so how what are the connections for the pressure gauge on the T. And what should the readings be?
Thanks Madness
checking crankcase pressure
volvomadness
- Year and Model: v70 2003
- Been thanked: 9 times
- Year and Model: Many Volvos
- Been thanked: 76 times
What pressure are you looking for? Oil pressure or crankcase vapor pressure?
The only way I know of to read the oil pressure is to install an adapter in the pressure sensor hole. Book spec on oil pressure is 43 PSI according to Haynes.
For Vapor pressure it should, in a prefect world, be zero. I use a balloon on the dipstick tube and see if it tries to inflate.
- 12 Replies
- 4160 Views
Last post by ShaverNS1
- 2016 Views
Last post by jonnycycles
- 3521 Views
Last post by Clemens
- 3600 Views
- 1541 Views
Last post by Henster
