1999 V70 T5 5 Spd.
ATmarine
Year and Model: 1995
Post by ATmarine »
I am contemplating selling my 1999 T5. This car is fairly rare as you may know. It has been cared for well by me, and the previous owner. However this past weekend the timing belt tensioner let go and she skipped timing. So now a head job is in order. This car is worth doing, and not scrapping. If there are no takers, I will do this. I am slightly burned out on car work at this time after just completing an engine sway, and head gasket replacement on 2 different cars. This drives home the point that you should never just replace the belt only.
Overview:
222K , 5 speed, power everything, cruise control, rear spoiler, black leather interior, everything works with exception to the sunroof. (track needs cleaned and lubed, have not done that....yet) I am the 3rd owner. Car is very clean inside and out. There is a couple of small scratches on the exterior, clear coat is in good condition, and the inside is nearly factory. No rips, tears, odors, stains, etc. I have done much to this car recently.
-new timing belt at 168K
-new Volvo OEM turbo
-all around new brake pads, discs, and rear calipers
-new parking brake cables
-new shocks all around with mounts OEM
-new rear heavy duty coil springs IPD
-new delta link bushings IPD
-new control arms, tie rod ends IPD
-new lower right engine mount
-new alternator OEM
-new electronic throttle module OEM
-new serpentine belt
-PCV system new
-left CV axle new
-left axle seal new
-new VVT solenoid
-plugs, wires, air filter, cabin air filter
-Volvo OEM floor mats - rubber
-Volvo OEM cargo divider - fold up, with new shocks
-lift gate shocks
-lift gate trim has been repaired
I have all receipts for the above work. I has all been completed in the last 11 months or so. Car ran, and drives like a dream. Just an utter disaster by not replacing the idler pulley and tensioner. I am asking $1900 for it as is. Car is located in the Hudson Valley NY. If there are no takers I will do the head job and drive again in the near future. Just too nice a car to scrap over this! I will post pics over the weekend as I am away right now. Call / text: two 07-seven 52-0831.
ATmarine
Post by ATmarine »
