Rough idle
gargray
Year and Model: S70,1999
Rough idle
Post by gargray »
I am having issues with rough idle and car goes into limp home mode
Model 1999 Volvo s70 100k miles
I bought a obd 2 code reader and it is throwing codes
P0645
P1620
P1081
P1026
P1031
P1017
P1021
P1026
P1031
I am using the action cp9125 reader is there a conversion from p codes to Volvo dtc codes?
I read on the forum that the maf may be the issue. I replaced it, and it didn't fix the problem
Pulled the etm fuse and etm would whine but not seem to shut off. Replaced fuse to etm started car and car ran fine until it was shot off and restarted. It then went back to rough idle and limp home mode
Wanted to confirm it is the etm before I replaced it
Thanks
midniteliquid
Year and Model: 2011 XC70 T6
Post by midniteliquid »
P0645 -- Air conditioning (A/C) relay -- Signal missing
P1620 -- Engine cooling fan low speed -- Signal missing
P1026 -- Throttle Body Internal Fault
P1081 -- Fuel immobilzer fault
P1031 -- Heated Oxygen Sensor -- Heater Current Monitor Control Circuit (Banks 1&2, Sensor 1)
P1017 -- Engine Control Module (ECM) internal failure
P1021 -- Electronic Throttle Module (ETM) fault
I would make sure all of the ground connections are good, but it looks like the ETM has gone bad and is causing other errors because of the incorrect fuel mixture.
Volvo #1: 1996 850 GLT (now my Sister's...)
Volvo #2: 1995 850 T5R (totalled... rear-ended by a woman on her phone)
Volvo #3: MY2011 XC70 T6 (current... I love, love, love this car!!)
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
I have a rough idle but only at stops so I'm guessing mine is an incorrect starter. I have a Regina ignition system and a Bosch starter. I heard the two don't cross integrate well. and since I've fixed everything else that could cause a rough idle: dirty TP sensor, dirty intake, dirty IAC valve, plugs, wires, rotor and cap, it MUST be the starter mis-match that's causing my problem. but G'Luck with your issue as well.
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
98T5
Post by 98T5 »
turns out my rumble is coming from bad motor mounts :x
