94, 940 wagon - 150,000 miles. Runs great. However there has been this annoying vibration at 3000 rpm - esp annoying at freeway cruise which is 3000 rpm. You can feel it everywhere in the car, very much so on the gas pedal.
I have new motor mounts, new trans mount. Harmonic bal is fine. I have a hunch, no, I am almost sure it is the belts. At 3000 I noticed a lot of deflection on the alternator belt. I installed new belts and the rubber mounts for the alt bracket. I really got them tight. Now, the car is as smooth as melted butter at idle all the way up to 2800 rpm and at 3000 the vibration comes back. It feels the same. When observing the belts there is very little deflection at all.
I am beginning to wonder if it coming from the ac. The car was converted to r134 with the volvo kit from the dealer years ago, I think the kit may be amplifying the problem - The return hose seems to be a bit shorter than I remember, it is rubbing against the firewall and the throttle cable. I put some pool noodle around it and it did have an effect.
So, the question is to all 700/900 owners who have switched over to r134. Have you noticed any excessive vibrations? Could you post some pictures? (I will shortly)
Cheers
Strong Vibration at 3000 RPM
I have a 93'940 that rumbles at idle. I found out it was my motor mounts. I will be changing those soon. if yours rumbles at high speed, I would suggest checking/cleaning your IAC valve, TPS sensor and intake with some carb cleaner. best case scenario. worse case scenario would be the injectors clogged and not adjusting to the need for fuel starving the carb. and hit your CAT with a rubber hammer, if it rattles, it's toast and that could be why you lose power also. also Check your O2 sensor, those are known to rob the car of power and will create a similar "rumble" to the engine at high rev.
Also, check your wheel hubs on both side, are they tight or loose? if loose, that could be your problem. jack up LF wheel and grab it at 10/2 and see if wobbles, if so, your wheel hub assembly is bad on that side. do the same with the other side. they may be trying to go out. I have a slight wobble in my RF wheel so I will chagning that one when I do my motor mounts.
Also check to see if your muffler hangers are tight. I found a few of mine loose when I bought it and tighten them up making the rattle less rattally to help me track down my rumble problem
G'luck.
G'luck.
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
Thanks for all the info. Its a vibration (Buzz) more that a rumble. Motor mounts are new, injectors were pulled and blueprint4d a year ago. I do not know about the IAC valve or TPS, I will check. Wheels are tight, I just out on new calipers, I checked. Front stabilizer bar mounts are dry.
I adjusted the compressor hose a little. Gave it more of a loop. Wrapped more pool noodle around it. I did make a difference, therefore it has to be the way the r134 kit was designed. (badly) I think I will go to a hose shop and have a longer setup made. Hell, I should go back to R12...
precopster
- Year and Model: Lots
- Been thanked: 128 times
If the A/C is not running and the compressor is off the vibration is likely not anything to do with the a/c system or type of refrigerant.
If the vibration only occurs during a/c operation when the compressor cuts in (you'll hear this as the solenoid clicks at intervals of between 10 and 40 secs) then the compressor itself may be failing.
The vibration is there AC system on or off. Its only related to the AC system as I think the conversion used an ass clown sort of a hose design/location. The source of the vibration is in the belts - no matter how tight they are there is deflection at 3000 rpm. That frequeny is then transmitted through the compressor and to the discharge hose and amplified like a guitar string. Padding the string reduces the frequency.
I know of know serpentine belt conversion for the B230. I could fab a idler pully to the alternator belt. Of course, these are big 4 cylinders, they are never going to be that smooth. The dealer kit has that hose attached with a P clamp to the firewall where it touches the brake booster and throttle cable. Just a nasty job.
BTW, when the belts are disconnected - there is no vibration at all. Nada. I might investigate getting shorter belts.
hahahatranmkp wrote:The vibration is there AC system on or off. Its only related to the AC system as I think the conversion used an ass clown sort of a hose design/location. The source of the vibration is in the belts - no matter how tight they are there is deflection at 3000 rpm. That frequeny is then transmitted through the compressor and to the discharge hose and amplified like a guitar string. Padding the string reduces the frequency.
warcraftjunkie
- Year and Model: 2008 XC90 3.2
One thing I haven't noticed in your thread is if it's at 3000 RPM in neutral or only when driving, or both? If it's only when driving may I suggest you look at the drive shaft that delivers the power to your rear wheels. I had a truck that used to make a horrible noise that could be felt/heard at higher speeds. Turns out I had a failing Ujoint on my drive shaft causing a vibration at a specific RPM range.tranmkp wrote:94, 940 wagon - 150,000 miles. Runs great. However there has been this annoying vibration at 3000 rpm - esp annoying at freeway cruise which is 3000 rpm. You can feel it everywhere in the car, very much so on the gas pedal.
Cheers
If you can't laugh at yourself, someday you will be the only one not laughing.
08 S80 V8 - My daily driver
08 XC90 3.2 - Wife's people hauler
87 245 DL - Son's car
- 644 Views
Last post by anier1985
- 471 Views
Last post by angeltease
- 896 Views
Last post by precopster
- 469 Views
Last post by wellomal
- 949 Views
Last post by arvik
