Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link
Buy your stuff using this and it helps MVS!
Turbo Coolant Leak
- Year and Model: V70 AWD turbo 98
- Has thanked: 0
- Been thanked: 0
Turbo Coolant Leak
I'm trying to fix a coolant leak on my Brother in law's 98 V70 AWD turbo. I've traced the leak to one of the coolant lines at the bottom of the turbo. It's leaking right behind the clamp. I don't know if it's the inlet or outlet line. The problem is how do you get to it to replace the hose? There's no room to get my hand in there. The clamp is a crimped one, and I can't see the other end of the hose. The only option I see is to pull the turbo to gain access, and I really don't want to go there. Am I missing something? Is there an easier way? I've attached a picture of the leaking hose.
You do not have the required permissions to view the files attached to this post.
- Year and Model: 1999 S70 AWD
- Has thanked: 0
- Been thanked: 0
Re: Turbo Coolant Leak
Very common failure. Oil leaks on to this hose and makes it extremely soft. Then it bursts.
Replace the other turbo coolant hose while you're at it too, the one above the exhaust manifold on the passenger side. (About 2" long, straight hose)
The fact that it's AWD makes matters much worse, the angle gear gets in the way of an easy repair. You'll have to remove the intake pipe going into the turbo and do most of the work from above.
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
- Has thanked: 0
- Been thanked: 113 times
I just replaced that hose on my 1998 S70 GLT, here is the DIY. The trick is to undo the Banjo bolt.
But drain coolant first.
DIY: 1998 S70 GLT Turbo Coolant Hoses and 2 Radiator Hoses
http://www.matthewsvolvosite.com/forums ... =1&t=55306
The AWD is more challenging, some people suggest that you do this from the top.
Just place a soft mat on top of the engine and lay on top of the engine while reaching down.
- Year and Model: '06 V70R
- Has thanked: 0
- Been thanked: 0
I just did this on my AWD and it really wasn't that bad. I did everything from above and it took me a couple of hours to remove the filter box and intake pipe, remove the old cracked hose (I just snipped the old hose clamps), install the new hose with new clamps (a small ratchet, long extension, and 7mm socket is the way to go), and re-install the pipe and box.
-Matt
-Matt
'06 V70R
- Has thanked: 0
- Been thanked: 0
Thanks everybody for your input. Supposed to have nice weather, so it looks like this will be my project for the day.
98 V70XC 2.5l turbo wagon coolant leak near heater inlet/outlet of engine
by rocky_mtn_man » Sat Jan 28, 2017 5:12 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 0 Replies
- 114 Views
Last post by rocky_mtn_man
Oil in coolant, sludge in coolant res. moist exhaust.
by Rick Almeida » Sun Dec 27, 2015 9:30 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 9 Replies
- 2106 Views
Last post by rspi
Thu Dec 31, 2015 10:21 am
1997 850 what kind of coolant used? Do I have coolant light?
by christhegamer » Mon Feb 29, 2016 3:31 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 13 Replies
- 1195 Views
Last post by Ozark Lee
Mon Feb 29, 2016 11:39 pm
Low Coolant - But not low on coolant...
by MathalomuleM31 » Sun Sep 04, 2016 5:16 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 8 Replies
- 1369 Views
Last post by MathalomuleM31
Sun Sep 18, 2016 6:10 pm
