440 cylinder head bolt torque.
molteniman
- Year and Model: 440 1995
Good afternoon. Before I torque the cylinder heads bolts on a B18U engine, I want to get the sequence right. The Haynes manual says 22 lbft, then 52, wait 3 minutes and slacken, then 15 lbft and finally angle-tighten 123 degrees +/- 2. However, the instructions with the head gasket (British Gaskets Group) say 22 lbft, the 50 degrees, then -180 degrees, then 18 lbft and finally 213 degrees. Which is correct, or do both arrive at the same tightness? Any help would be gratefully appreciated.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The attached corresponds with the Haynes manual and is from a reputable trade book.
Before starting lightly oil the screw threads and the bolt head mating surfaces then put them in finger tight.
I wouldn't think that the gasket instructions are correct as the final 213 degrees is a lot more than 123 degrees and would result in the head being too tight.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
molteniman
Many thanks for lightening response. Weather permitting, I'll finish the job tomorrow. Fingers crossed.
molteniman
Sorry! Mispelt lightning.
- 496 Views
Last post by capkrokus
- 17884 Views
Last post by beoutside
- 1375 Views
Last post by erikv11
- 2201 Views
Last post by precopster
- 13 Replies
- 8438 Views
Last post by lifeofgold
