IPD sale Volvo Parts
1999 V70T5M56 AC evap 9171781 and heater core 9144221 replacement (Pics end of thread)
98T5
Year and Model: V70T5,98' / 940,93'
United States of America
Re: 1999 V70 T5 AC evap and heater core replacement
Post by 98T5 » Fri May 10, 2013 1:30 pm
Question:
YOu were able to take the dash out one of the doors...I'm wondering if one could also take it out the back tailgate also then? turn it the long way? maybe? no? yes?
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
Year and Model: Lots
Has thanked: 3 times
Been thanked: 71 times
Australia
Post by precopster » Fri May 10, 2013 3:28 pm
98T5 wrote:Question:
You won't get it past the back seat if you do it that way. I took mine out of the passenger door with good clearance and with the help of the other (more delicate) hands in the household.
Current cars:2002 XC70, 2001 V70 T5, 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 130 times
Been thanked: 405 times
Trinidad & Tobago
Post by abscate » Fri May 10, 2013 6:35 pm
Would definitely recommend one helper on passenger end of dash, and removal out the driver door.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
Trinidad & Tobago
Post by abscate » Fri Jun 28, 2013 5:55 am
Here is a look at the Electronic Climate Control removed from the car, annotated.
Note the large pin which you need to wiggle free of the dash on driver side.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Trinidad & Tobago
Post by abscate » Fri Jul 13, 2018 4:09 am
Old thread alert
I have a massive pic database from this project so checking with Matt to see how best to handle.
Might just link to drop box or like, tbd.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Trinidad & Tobago
Post by abscate » Fri Jul 13, 2018 6:37 am
Abscate rule - buy two of and replace every Oring that you touch on HVAC
I had to replace this hard line, but install was a breeze.
Would love to tell you what this is - Not a clue..
The tool expands that spring, which lets the trombone end slip out . Good luck The aluminum corrodes the steel making it tough to twist and break free. Cut the evap and save an hour of swearing.
Double O rings
Dash back in
Fitting heater core screws
Dash back in
Ready to load heater core
a
Dash coming out....
ttachment=15]VOLVO AC EVAP APR 2013 - 2 (3).jpg[/attachment]
Seats out, console out
Close up of how the spring/bayonet connections function
What happened to my car??
About one gallon of coolant removed from rear pass side
Tight Torx clearance on heater core bulkhead bracket
I found Yellow retainers from VOLVO kit too long, so I re-used old ones
Removal tool for AC lines - brute force method - NOTE - I am cutting evap, not the expensive AC lines!
Ugly mess. The captive M6 in the frame member broke free, so I had to drill out the M6 to release the receiver. Chances of getting an old receiver out of car in place - near 0.
You can crack compressor lines with it in place with long extensions working from Driver Side, as pictured. The hand points to the fastener being removed
Tools to split office line and office part itself
Another close up of AC fittings
Double Orings on some of these?
Tension method to remove old heater hoses
You will have to gently bend the hoses to duplicate position - note retainer plastic which holds position
]t]]]]]
Quick to this stage - 2,3 hours IIRC?
Vroom
Cut out door on HVAC
]]]]]]]]t]
EVAP HVAC
ORifce tube line opening - I had to go back as I put in backwards first time Was able to do this with two open ends.
HVAC detail
Two sizes of clips but easily sorted
Cut off old receiver, new one goes on easily
two sizes of fasteners on HVAC - mark them with sharpie
Yuck...
HVAC wiring detail
New lines are a breeze
OEM heater core failure
HVAC view installed
The ECM cooling pipe can be a pain to get back in right Get it right before replacing ECM housing
This would have leaked really badly :-)
New Evap detail
Clearing TPS (pedal sensor on ETS cars) - I remember this was a pain to do - needed deep M6 socket
Steering shaft closeup
Nasty Orings and tool
EVAP core line retainer detail
Pop bracket off, then cut the Aluminum evap lines (not the steel) to make this a snap
Whew!!
My $50 Snap on AC tool
Heater core goiing in
Close up on old EVAP installed in HVAC, before closing
You can just snark this off in place (right in front of timing cover with two large open end wrenches
new and old Heater core
HVAC unit, removed
Note where I cut carpet and liner to de-grease/coolant
These users thanked the author abscate for the post:
brunocerous
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 6 times
Re: 1999 V70 T5 AC evap 9171781 and heater core 9144221 replacement (Pics end of thread)
Post by sleddriver » Fri Jul 20, 2018 3:54 pm
Wow...what a mess. Amazing how cars rust up North.
Thanks for the pics.
M1 10W-30 HM
brunocerous
Has thanked: 26 times
Been thanked: 5 times
Post by brunocerous » Sat Jul 21, 2018 8:55 am
Amazing job and pictures! My brother is gearing up to do this job, too.
1998 V70 T5, AT, project
1999 V70 XC AWD, AT, project
1998 S70 T5, AT (RIP)
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 24 times
Been thanked: 21 times
Peru
Post by theWIFES_S70 » Mon Jul 23, 2018 12:18 am
Hahaha, yeah, I would have attempted this except that, you know, my brother dumped a VR6 timing chain job in my lap... :)
Bravo, abscate! I love the documentation. I'm inspired!! I'm wondering though, how many hard lines should I replace prematurely... Did you replace Volvo 9171406? https://www.fcpeuro.com/products/volvo- ... pe-9137406
These hard lines are pricey!
1998 Volvo S70, N/A, 5-speed, 180K
Trinidad & Tobago
Post by abscate » Mon Jul 23, 2018 2:46 am
I replaced that one and also the drier to condenser return line due to corrosion
There are three fasteners that separate you from Nirvana on this job.
The two 6 mm hex screws that hold the hardline behind the right head light..you can see the mess I made when one of the captive fasteners broke
The hex holding the suction line into the compressor. This is the one I got to with the long extension
Once those three are out, all of the hard connections can be dealt with on the bench and not on the car. The drier connections are big , 20mm+ nuts which will be locked tight and there is no clearance on car to snarf these off.
Up top, you can heat and apply pure torque , all is good.
Separating the trombones from the hard lines is also easy out on the bench
Replacing the orfice tube in place looks doable with another high pain factor. Look at the clearance for the 19 and 22 mm open end, and you don’t get pure torque with these. Crows feet probably required, and careful wrenching, or get it on the bench and 15 seconds. Not sure how you are going to keep things clean there either
Hours of hard wrenching and knucklebusting turn into minutes
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Who is online
Users browsing this forum: Cookeh, ecbsykes, Rubenrodri126, WhatAmIDoing and 74 guests
