trailer wiring question...
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
I know there is a tail in the rear trunk of my XC70 (2003) that can attached to a Volvo factory trailer wiring harness, but...
Has anyone used a standard generic one with success? I have to have an extra new unit setup for european lights (vs. Japan) and want to know if tapping such a solution into the existing wiring causes any issues with light warning lights (changed impedance?) or other such issues that can be seen with trailer wiring.
what "real world" success or failures can anyone talk about?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
jimmy57
Been thanked: 322 times
Post by jimmy57 »
You have to use a powered trailer light converter. If you google that you'll find themat U-Haul stores and many auto stores. This unit will only use the connections to tail, turn, and stop as signals so the bulb failure system will not go whacko and you will not stress the REM and its shunts. You can use a self reset circuit breaker also sold at these places (20-30 Amp) and get power supply next to battery at the fusible strip center there.
jeljm
Year and Model: S60, 2005; XC70,2007
Post by jeljm »
I have used the uhaul wiring harness with great success on my 98 v70. You just have to run a line (supplied) from the lighting unit to the positive terminal on your battery (it'll connect via a fuse), then use the supplied taps to connect to the appropriate wire that drives the lights in the rear. I used a circuit tester to determine which was the correct one. You also need to ground the box to something in the trunk most unpainted screws will work. Once you're all done the unit will have indicator lights to tell you if it's functioning. It took me about an hour and I took my time.
'98 V70 GLT at 250,000 miles which was recently sold.
'05 S60 2.5T at 120,000 miles which is perfect.
'07 XC70 at 110,000 miles almost fully loaded and beautiful.
auburneduprof
Year and Model: 2002 V70
Post by auburneduprof »
For me, nothing like the $109. OEM one from IPD. 3 minutes to install, the right grommet, and my trailer lights are brighter than they've ever been. I'm cheap, but it was a no-brainer for me.
2002 V70 150k
2011 Hyundai Sonata
1996 West Wight Potter w/lapper and 140% Genoa.
CamZH
Year and Model: '94 850 + '04 S60 R
Post by CamZH »
Do you have a link to the OEM harness ?
I'm looking to add a towbar to my S60
2004, S60R
1994, 850 T-5 Wagon
CamZH
Post by CamZH »
So I got a wiring harness from a local dealer (part no 30681 980)
Looks nice and easy to install,
But the dealer tells me I need to have some programming done to make this work.
Sounds like a load of BS to me.
Can anyone add anything to this ?
2004, S60R
1994, 850 T-5 Wagon
auburneduprof
Nope. Plug and play. At least it was for my 2002 v70.
2002 V70 150k
2011 Hyundai Sonata
CamZH
Post by CamZH »
Got this installed on the weekend,
Was plug and play for me also (with the extra fuses into the rear fuse box)
2004, S60R
1994, 850 T-5 Wagon
mglass
Year and Model: V70 2002, C30 2008
Post by mglass »
Does this mean the V70 has it's own converter or is that in the oem wiring harness? And what is an IPD?
I already purchased a Curt tail light converter before I read this forum and am now wondering if I can tap into the wires on the connector or if I even need the converter.
bskeels
Year and Model: 1997 Volvo 960
Been thanked: 3 times
Post by bskeels »
The V70 does not have its own convertor, IPD is a company that specializes in Volvo oem parts and performance parts. You will need the convertor to make your trailer lights function properly. A convertor is needed any time you have separate turn signals and brake lights.
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
