When I connected my ground cable after the car had been sitting for a couple of months, I noticed a little spark with the key not in the ignition and doors closed. I think that might have killed my battery when I left the key on for 2 hours to re-code the radio.
Question: Can a key off current draw be traced through the fuse panel? Any other easy way (please???).
A hearty thank you for a quick method!
key off current draw, 850
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
I'd consider that leaving your key on for 2 hours is what may have killed a poorly charged battery.
If you need to recode the radio, maybe run the car for 2 hours instead of just letting it discharge?
Go for a nice drive - Get out - See the sights.
Or perhaps put it on a battery charger
while you leave the key on?
Just some thoughts.
Just some thoughts.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
A small spark is normal when reconnecting the battery.
You can test for current draw on a properly charged battery across the terminals. It should be <35-45 mA. If it's higher than that, yank fuses until you find out what's drawing current.
'98 S70 T5
2016 Chevy Cruze Premier
mynoralvarez
- Year and Model: 850 GLT 1995
Just my experience... I had a faulty switch in the glovebox that kept my car's battery diying for over a month... just for curiosity removed the bulb and Voilá no more running out of battery so you might want to check if that is your issue.
holyjaguar
- Year and Model: 1993 940 Wagon
Yep me Too,I use a folded tissue to "fool"the glove box switch,rather than remove the bulb in my already dimly lit glove box,.....
- 953 Views
Last post by RickHaleParker
- 15 Replies
- 606 Views
Last post by JeffreP
- 2303 Views
Last post by sleddriver
- 212 Views
Last post by andyleonard
- 84 Views
