96 960 Will not idle once warm
Ryan
Year and Model: 1996 960
Post by Ryan »
Hello,
I have a 96 Volvo 960, only 114k miles, and has been well maintained. Having a devil of a problem, as it starts perfectly, runs for 6-7 minutes, then immediately dies, every time. The car runs perfectly though when accelerating and driving at steady speeds; just dies at every stop sign or light... No codes or check engine light showing.
I've replaced the IAC Valve; no luck. Cleaned MAF Sensor with expensive spray; no luck. What would be appropriate next steps? Considered replacing throttle sensor, plugs?
Any help would be wonderful!
Thanks,
Ryan
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
If you leave the car to idle without driving does it die every time? Does it immediately start?
I'm going for something here that will kill all ignition like a cam or crank sesnor problem. Even a fuel pump relay will do this.
These cars have 2 separate ignition modules so if one dies 3 cylinders are left.
Ryan
Post by Ryan »
Thanks so much for your reply! :)
Yes, it will die every time without driving. It does immediately start, very promptly and idles smooth for just that time until it's warm. Then, it will start again, but just die out within a minute.
When it does idle when cold starting, it runs so smooth and even...then continually dies after warming.
Thanks,
Ryan
JohannReinhard
Year and Model: 940 GL 1992
Post by JohannReinhard »
Honestly, I'm going to take a SWAG here (Scientific Wild-Arsed Guess) and say that something in the car is killing the engine on purpose, likely the crank speed sensor. I've heard of these sensors causing automatic shutoffs when they go bad. A car will drive fine for up to 20 or 30 minutes, and as soon as the engine warms up to operating temperature the car dies. This was a problem with a friend's 940, and if they're in the same position on your 960, then that sensor is likely overdue for replacement.
IPD sells a replacement sensor for $50, though you may find it cheaper elsewhere.
Hope that helps, I'm no expert in the 960. :|
Restoring the 940, One Part at a Time
http://volvo940restoration.blogspot.com
Ryan
Post by Ryan »
Really appreciate these responses.
Sorry for my lack of full awareness here, but where is this located? I'll buy one right away and replace.
Thanks for everyone's help; can't wait to get my ride running properly again.
precopster
Try cam sensor first at rear of exhaust cam.
The crank sensor is a bear to get to on the 960 as it's down deep at the top of the gearbox where it meets the engine. You might want some help with that one anyway. It's held in place by a 10mm bolt.
