Over the past 5,000 miles or so I have heard my front right wheel bearing making a little noise. It hasn't gotten much worse but it's best to replace them before they come apart or tear something else up. I have a 1995 Volvo 850.
I used a OEM Volvo bearing (so I was told) which I purchased from eBay. I have read that a company named FAG makes bearings for Volvo. They also make the bearings for Timken. Anywho, I would like to think I have a bearing that will last another 227,800+ miles, that's why I went with Volvo. Unfortunately I have read that someone had an OEM bearing go out on them in less than 15,000 miles. We'll see (I plan on driving this car for some time).
Volvo 850, S70, V70 Front Wheel Bearing Replacement - Video
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
This post was great help changing the wheel bearing in a 2000 V70 x/c. I deviated from what Robert showed by removing the strut assembly instead of the control arm. this allowed the axle to be easily slid out of the bearing hub. I used a steel rod in the top hole on the hub where the caliper bolt penetrates to stabilize the casting to R &R the bearing hub.
Robert has many videos showing fixes on our cars. Just wanted to say thanks.
- rspi
Contact rspi..
Glad it helped.
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
I referred to VADIS for the procedure and it is essentially as you show it.
One thing is that VADIS refers to applying a 3-4mm wide bead of metal adhesive around the outer sections of the spline on the axle before inserting the axle into the new bearing. The metal adhesive is Volvo part#116137-0.
I have never heard of metal adhesive.
My tendency would be to apply some anti seize but I certainly would not call it an adhesive.
Did you or do others apply something to the spine at assembly?
Thks,
Dwight Carlson
97 850 T5
Thks,
Dwight Carlson
97 850 T5
- rspi
Contact rspi..
Anti seize.
Thanks for the video Robert, that's a great help. The difference in price between a Volvo part and a pattern part is extraordinary. Volvo are at least three times the price. I was told Volvo use the same wheel bearings as Rolls Royce... at the price they charge I jolly well hope so
1995 Black 850 T-5R Saloon 210,000 kms
- rspi
Contact rspi..
I think I paid about $95 US for the one I got from eBay.
- rspi
Contact rspi..
Yes in a Volvo box.
- Has thanked: 1506 times
- Been thanked: 3819 times
I started feeling a little shake at 70 mph, and in the cold weather I can here a low growl that is load dependent on the driver side. Classic bearing noise.
Ordered all the parts, but will wait for warm weather to do the deed.
