question about vag-com cable and software for v70 2000
piesia
Year and Model: v70 2000
Post by piesia »
Matty Moo wrote: Get yourself a vag-com cable and a copy of vol-fcr, you'll be under $20 all in and have all the diagnostic goodies you'll ever need for that car.
Hi, Matty Moo and others!
I pulled this out of another thread because I wanted to ask a more generic question, if that's ok?
where do you find a vag-com cable for a volvo v70? are they all the same? the ones I've seen say VW/audi
what software do you recommend for volvos, is vol-fcr generic? Is there software for apple or android smartphones and/or another hardware dongle available for iphone or android phones to read codes on the phone? Is there any mac software that someone would recommend? (less important, I'd prefer to use my phone, if it works that way).
Thanks very much!
best regards,
P.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
You can find vag-com cable on e-bay.
Vol-Fcr is not a generic fault code reader,it's Volvo fault code reader.
There is a software for apple & android phones but you will need a proper interface for communication between the phone & the car...also available on e-bay. :wink: It's a bluetooth obdII adapter/interface.
Vol-Fcr is for volvos up to '98(including '98).
With android or apple software you can track live data from your car.
I don't know how true the live data is from phone software but the rumour says that the data is valid.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
piesia
Post by piesia »
thanks, Misha!
does that mean versions of vol-fcr up to 1998 work on volvos or any version of vol-fcr works on any volvo up to the 1998 model year? I have a 2000 v70 so if the latter, I'm out of luck and this will not work for me , I guess!
I appreciate your advice.
Best regards,
P.
misha
Post by misha »
piesia wrote:...does that mean versions of vol-fcr up to 1998 work on volvos or any version of vol-fcr works on any volvo up to the 1998 model year? I have a 2000 v70 so if the latter, I'm out of luck and this will not work for me , I guess!...
Engine codes(read & erase) will work only for Bosch Motronic 4.4 engine menagement.'98 should be all Motronic 4.4 ,turbos or n/a.There are also a versions with Motronic 4.3.(depends on market).European market is pretty much different from U.S or U.K market.
All other codes....abs,ac,transmission,power seats,immobiliser,srs,service light reset...etc are fully compliant.
I have '97 850 with Motronic 4.4 and Vol-Fcr is more than usefull to me.
Bad news are that Vol-Fcr will not work on your 2000 v70.It should have Denso engine menagement.But good news are that you can buy cheap generic code readers from Autel or some other brand that will read & erase your engine codes.For access to any other ecu in the car you'll need a special Volvo tool.
Misha.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
piesia
Post by piesia »
misha wrote:Bad news are that Vol-Fcr will not work on your 2000 v70.It should have Denso engine menagement.But good news are that you can buy cheap generic code readers from Autel or some other brand that will read & erase your engine codes.For access to any other ecu in the car you'll need a special Volvo tool..
ok, thanks, Misha, for the information!
best regards,
P.
misha
Post by misha »
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Min. Order: 500 Pieces
let's get a group buy going
although for the other (identical) ones on that page, i must admit i never knew sellers on alibaba sold just one unit of anything
misha
Post by misha »
That's for comparison only.They can be found on e-bay or amazon per piece. :wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
flash3b
Year and Model: 2005 S40
Post by flash3b »
I've been using an inexpensive Actron scanner for a while on my '98 S70's. Can the Volvo-fcr software do anything that my scanner can't? Also, if I get one of these vag-com cables (hilarious name, BTW) where can I download the software from? Or do I have to buy a disc?
piesia
Post by piesia »
Extremely helpful! thanks!
best regards,
P.
