'01 V70 T5a, 148,xxx miles and I drive it ~25 miles one way to and from work every day, plus weekend jaunts. To my knowledge, factory exhaust header to tailpipe. It seems to run fine, consumes maybe a half quart of oil between 7.5k mile changes and gets about 21-23 MPG on those 25 mile commutes.
So the DMV sent my registration notice a couple weeks ago and it had the dreaded SMOG Test Required notification on it. So I take it to the smog shop in Irvine and it passes. Barely. Comes within 2PPM of failing the 15MPH hydrocarbon test. Everything else seems fine. On the top of the test certificate it did have the car flagged as "Inspection Reason: High Emitter Profile".
15mph, 1659 RPM, 14.9% CO2, 0.0% O2
HC PPM - max 52, avg 4, meas 50
CO% - max 0.49, avg 0.01, meas 0.10
NO PPM - max 425, avg 27, meas 178
25mph, 1609 RPM, 14.8% CO2, 0.0% O2
HC PPM - max 36, avg 4, meas 21
CO% - max 0.47, avg 0.01, meas 0.03
NO PPM - max 712, avg 26, meas 28
What should I be looking at to make sure that it can pass smog later in its life?
'01 V70T5 Almost failed smog, high HC
WhiskeyTangoFoxtrot
- Year and Model: 2001 V70 T5a
- 12 Replies
- 617 Views
Last post by SlowandSteady
- 782 Views
Last post by 93Regina
- 910 Views
Last post by Volvo S80
- 2370 Views
Last post by msyverts
- 34 Replies
- 6531 Views
Last post by rspi
