Hi everybody, I want to know if someone know why my first start engine of the day has this behavior.
First start and dies instantly, in the second try it works great.
Hi I post a Video.
Thanks
Engine Start fail
- Year and Model: Many Volvos
- Been thanked: 76 times
Check the fuel pressure after the car has been turned of for a few minutes. It should still be a positive pressure around 25 or 30 PSI. If it has fallen to zero that explains the problem on startup.
The fuel pressure is maintained by a check valve in the fuel pump and you can either replace the fuel pump assembly (the check valve is built into the housing) or install an aftermarket check valve in the fuel line.
nicopag
- Year and Model: v70 2.5T, 1999
Are we talking about this? http://www.ebay.com/itm/93-04-VOLVO-850 ... fd&vxp=mtr
Is there a way to fix them?
V70 2.5T, L.H.D /S.R, 1999
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The check valve is an intergral part of that assembly.nicopag wrote:Are we talking about this? http://www.ebay.com/itm/93-04-VOLVO-850 ... fd&vxp=mtr
You can splice a check valve into the fuel line after the pump, as Lee mentioned...or replace the whole assembly with a used one.
'98 S70 T5
2016 Chevy Cruze Premier
- 2033 Views
Last post by Dmck
- 18918 Views
Last post by jonesg
- 237 Views
- 42 Replies
- 1763 Views
Last post by CIK7
- 1704 Views
Last post by Kazthebassman
