Need radio code for SC-816
whitemountainnut
Year and Model: V70 XC - 1998
Post by whitemountainnut »
Hi eveyone! I know there's a couple of dealers on here so hopefully someone can help me out. I recently replaced the PNP switch in my 1998 V70 XC and naturally the radio no longer works. I believe it to be the original radio for the car.
Information you'll need:
VIN# YV1LZ5649W2442129
Serial# VO8170 V9279116B
I'm not incredibly worried about anyone reading this and stealing my radio so responses in the forum are fine.
I did also play with radio a bit, so now it doesn't say "CODE" anymore, it just says "OFF"". Is this a major issue and how do I get back to enter my code once I get it?
Thanks for the help!
-Scott
1998 V70 XC - 159k - Sandstone Metallic
1998 V70 XC - 220k - Dark Olive Pearl (parting out)
Has thanked: 1611 times
Been thanked: 4075 times
You will need to turn the ignition on and let it sit for 3-4 hours before you can try the correct code again, if its like my 99
whitemountainnut
I hope that isn't the case :-( But if yours is the same model radio then I will assume it probably is the case. Bummer dude. I do have a working radio that I pulled from my other car so it's not like I'm driving in silence, but it's not the radio that came in the car and it's a bit worn.
Thanks for the response! One item down, now I just need to get the code :-)
-Scott
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
It's 2 hours, not 3-4, or just drive for 2 hours and don't turn the key off
If it is an original radio, I should have your code in a few minutes for you
whitemountainnut
Thank you JRL! I appreciate the help! I suppose it would be groovy to know if that happens to not be the original radio. It's supposed to be.
-Scott
JRL
Post by JRL »
I'll need the rest of the numbers on the radio
whitemountainnut
Hopefully this picture is readable. The numbers below the 3533771-1 are 4980 on the left and 9709 on the right. There is also the number 816GB printed on the side of the radio.
-Scott
JRL
Post by JRL »
Will be tomorrow
whitemountainnut
Thanks JRL! VERY much appreciated :-D
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
How to find the code in case it's around your car somewhere:
How to enter the correct code:
