1994 850 radio cassette question
merisol1
Year and Model: 850,1994
Post by merisol1 »
water entered car and most likely shorted out the radio (per mechanic)
How can I determine if the radio has shorted out?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The term Shorted Out is largely a catch-all phrase. Rather than focus on the terminology try to use the radio. If it turns on and operates then it is fine. If it blows the fuse or is otherwise inoperable then it is bad. The SC-810 / 811 / 813 series radios with the cassette are really cheap - typically about $35.00 to $50.00 on eBay. The SC-816 series with the CD player typically goes for around $100.00 to $150.00 on the used market. The radio will swap out in a couple of minutes even if you have never done it before.
If you do buy a used radio it is always a plus if it comes with the code. If it doesn't have a code with it your local Volvo dealer will provide it to you for free. They need all of the numbers and I typically take the whole radio in to the parts counter and let them punch in the numbers that they need.
I am moving this post to the audio forum.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
815-816s are way less, $60-$85
