IPD sale Volvo Parts
2000 Volvo V70 Cross Country X/C SE AWD
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
jpr0204
Year and Model: 00' V70 X/C SE
Post by jpr0204 » Fri Jun 28, 2013 7:53 am
Maintenance Records and Repairs by the 1st Original Owner
05/23/00 – 10 Miles – Burdumy Volvo – Pre-delivery inspection completed and state safety inspection completed.
10/16/00 – 3,619 Miles – Burdumy Volvo – PCM checked and airbag system checked.
04/26/01 – 8,437 Miles – Burdumy Volvo – Recommended maintenance performed.
08/17/01 – 11,622 Miles – PA Inspection Station – Passed emissions inspection.
10/05/01 – 12,344 Miles – Burdumy Volvo – Recommended maintenance performed.
12/04/01 – 13,271 Miles – Burdumy Volvo – Hazard light switch replaced.
04/15/02 – 15,663 Miles – Burdumy Volvo – Recommended maintenance performed and front brake pads replaced.
11/02/02 – 19,169 Miles – Burdumy Volvo – Wipers replaced and recommended maintenance performed.
04/28/03 – 21,662 Miles – PA Inspection Station – Passed emissions inspection.
12/13/03 – 25,012 Miles – Burdumy Volvo - Maintenance reminder light reset and oil and filter changed.
01/07/05 – 32,696 Miles – Burdumy Volvo – Turbocharger oil line seals replaced, front brake pads and rotors replaced, and recommended maintenance performed.
09/10/05 – Burdumy Volvo – Computer reprogrammed, serpentine belt replaced, hub caps/wheel covers replaced, front brake pads and rotors replaced, engine mounts replaced, ABS computer/module replaced.
11/18/05 – Burdumy Volvo – Vehicle serviced.
02/03/06 – Burdumy Volvo – Battery replaced, sway bar links replaced, recommended maintenance performed.
04/06/06 – Burdumy Volvo – State emissions inspection completed, state safety inspection completed, oil and filter changed, and PCM Checked.
04/07/07 – Burdumy Volvo – State emissions inspection completed, state safety inspection completed, and recommended maintenance performed.
03/22/08 – 50,852 Miles – Burdumy Volvo – State emissions inspection completed, state safety inspection completed, front brake pads replaced, rear brake pads replaced, and recommended maintenance performed.
06/27/08 – Burdumy Volvo – 53,624 Miles – Vehicle is offered for sale.
09/04/08 – Burdumy Volvo – State emissions inspection completed, state safety inspection completed, and oil and filter changed.
01/06/09 – 54,256 Miles – Online Listing – Vehicle offered for sale.
01/08/09 – Burdumy Volvo – Oil and filter changed, cup holder replaced, and fog light bulbs replaced.
01/08/09 – 54,359 Miles – Burdumy Volvo – Vehicle sold to 2nd owner.
Maintenance Records and Repairs by the 2nd Owner
01/08/09 – 54,359 Miles – Burdumy Volvo – Vehicle purchased reported, vehicle purchased by 2nd owner, service contract issued.
02/11/09 – 55,190 Miles – Keystone Volvo – Vehicle serviced.
02/18/09 – 55,276 Miles – Burdumy Volvo – Vehicle serviced.
02/23/09 – PA Motor Vehicle Dept. – Title issued/updated, new owner reported, loan/lien reported.
04/03/09 – Burdumy Volvo – Replaced catalytic converter assembly.
07/27/09 – 59,866 Miles – Keystone Volvo – Maintenance inspection completed, oil and filter changed, and recommended maintenance performed.
10/26/09 – PA Motor Vehicle Dept. – Title issued/updated, registration issued/renewed, registration updated when owner moved the vehicle to a new location.
11/28/09 – 64,026 Miles – Volvo of Ft. Washington – Vehicle serviced.
01/23/10 – 65,397 Miles – Volvo of Ft. Washington – Vehicle serviced.
05/03/10 – 67,674 Miles – Volvo of Ft. Washington – Oil and filter changed, throttle body cleaned/serviced, tires rotated and balanced.
10/18/10 – PA Motor Vehicle Dept. – Registration issued or renewed.
01/11/11 – 74,440 Miles – Volvo of Ft. Washington – Front wiper blades/refills replaced, state emissions inspection completed, state safety inspection completed.
11/09/11 – PA Motor Vehicle Dept. – Registration issued or renewed.
04/30/12 – 93,848 Miles – Volvo of Ft. Washington – Vehicle serviced.
06/07/12 – 94,798 Miles – Volvo of Ft. Washington – PCM checked, Electric Throttle System/Throttle Body Assembly replaced, PCM reprogrammed.
Maintenance Records and Repairs by the 3rd Owner (Myself )
12/16/12 – 101,422 Miles – I purchased the vehicle for $3,000 from the 2nd owner.
12/17/12 – I purchased an engine oil dipstick, timing belt, timing belt idler pulley, timing belt tensioner, water pump, air filter, fuel filter, cabin air filter, serpentine belt, oil filter, 10W-30 motor oil, thermostat, thermostat gasket, rear upper motor mount, front right lower motor mount, front brake hoses, front right outer tie rod end, rear parking brake cables, heater core, and heater core o-rings - $495.22
12/17/12 – 101,465 Miles – Replaced all the above mentioned parts replaced plus change the front bevel gear oil in the front differential, change the gear oil in the rear differential, change the automatic transmission fluid, change the power steering fluid, change the brake fluid, change the coolant, and replaced the shifter bulb for the center console replaced
12/21/12 – I purchased front and rear beam type wiper blades and headlamp wiper blades. - $19.62
12/21/2012 – 101,485 miles - R&R front and rear wiper blades and headlamp wiper blades.
12/22/12 – 101,528 Miles – Went to Jack Williams Tire & Auto and had 4 Khumo Ecsta LX Platinum 205/55/R16 tires mounted and balanced and also had a 4 wheel alignment performed. - $702.92
12/26/12 – 101,837 Miles – I purchased 1 H-7 low beam headlamp bulb. - $2.52
12/26/12 – R&R left front low beam headlamp bulb.
12/26/12 – 101,850 Miles – Went to start vehicle for the first time of the day, vehicle started, ran for a second, and stalled. Went to restart and vehicle was very difficult to get started again. After being able to get the vehicle to restart, the “check engine” lamp came on. I hooked up my OBDII scanner to retrieve the codes. There were two codes in the computer. P1174 (Manufacturer Specific Air/Fuel Metering Device) and P1172 (Fuel System Running too Rich on Bank 2) which points towards the Mass Air Flow Sensor.
12/26/12 – 101,865 Miles – I purchased am A1-Cardone remanufactured Mass Air Flow Sensor. - $63.60
12/26/12 – 101,865 Miles – R&R Mass Air Flow Sensor, hooked up my OBDII code scanner, reset the check engine light, started vehicle, vehicle started right up with no “check engine” light at this time.
12/27/12 – 101,900 Miles – Drained and refilled automatic transmission fluid with 3.5 quarts of Dexron III/Mercon.
01/21/13 – 102,825 Miles – I purchased an Interstate Mega-Tron Plus MTP-48/H6 battery and a CR-2016 keyless entry remote battery. - $94.99
01/21/13 – 102,825 Miles – R&R battery and keyless entry battery
01/22/13 – I purchased an H-1 fog lamp bulb. - $1.74
01/22/13 – 102,880 Miles – R&R right front fog light bulb.
01/23/13 – I purchased an H-7 headlamp bulb. – 2.52
01/24/13 – 102,920 Miles – R&R right front headlamp bulb.
02/16/13 – I purchased 4 quarts of Dexron III/Mercon automatic transmission fluid. - $8.10
02/16/13 – 103,500 Miles - Drained and refilled automatic transmission fluid with 3.5 quarts of Dexron III/Mercon.
03/14/13 – I purchased an oil filter, 10W-30 motor oil, automatic transmission fluid, 2 Sachs Super Touring Struts, 2 Sachs/Boge Coil Spring Seats, and a coolant temperature sensor. - $336.78
03/18/13 – 104,423 Miles – I changed the engine oil and filter, automatic transmission fluid drained and refilled, coolant temperature sensor replaced, front struts and coil spring seats replaced, wheel alignment performed (by indy shop), front bevel gear oil level and rear final drive oil checked ( both were okay), checked radiator cooling fan due to fan continuing to run after shutting vehicle off and looked at an intermittent extended/long crank on a hot restart (put in that new coolant temperature sensor and see if it continues to display those two issues)
04/02/13 – I purchased an upper and lower radiator hose, 4 hose clamps, and a serpentine belt tensioner pulley. - $42.29
04/03/13 – 104,905 Miles – I replaced the upper and lower radiator hoses and hose clamps due to age and that the lower hose had a slight leak, serpentine belt due to the one that was replaced in December was already starting to wear due to the belt tensioner pulley, and serpentine belt tensioner pulley due to noise and causing belt to wear out prematurely.
06/03/13 – 106,625 Miles – Brought vehicle to Jack Williams Tire & Auto and had a tire rotation and balance performed. – N/C (Cover under tire protection plan.)
06/04/13 – 106,657 Miles – I purchased a left front fog light bulb. - $1.75
06/04/13 – 106,657 Miles – Found left front fog lamp assembly to have crack in the plastic housing allowing water to enter and fill up which blew the bulb. I removed the left front fog lamp assembly and bulb holder. Cleaned out the inside of the fog lamp assembly, replaced bulb holder, and epoxied the crack in the plastic housing. Let epoxy cure, reinstalled fog lamp assembly and R&R fog lamp bulb.
06/13/13 – 107,000 Miles –R&R left front headlamp bulb.
06/22/13 – 106,325 Miles – I purchased a premium Mann oil filter, 7 quarts of Cam 2 Pro-Max Synthetic Blend motor oil, and 4 quarts of Dexron III / Mercon ATF - $26.95
06/22/13 – 106,327 Miles – Performed 10W-30 L.O.F. and drained and refilled automatic transmission fluid with 3.5 of DexronIII/Mercon.
Current Vehicles:
00' Volvo V70 X/C SE (girlfriend's car) Currently at 112K miles
12' Yamaha V-Star 950 EFI Tourer (My daily summer crusier) Currently at 7K miles
95' GMC Yukon SLT 4x4 4-Door 5.7L 350 V-8 Currently at 120K miles
jpr0204
Re: 2000 Volvo V70 Cross Country X/C SE AWD
Post by jpr0204 » Wed Aug 14, 2013 12:46 pm
07/24/13 - 108,000 Miles - R&R fuel pump assembly and o-ring (which included lowering rear suspension subframe and all related components.) - $834.00 ($354 for Genuine Volvo Pump and O-Ring and $480 for labor)
Current Vehicles:
dwmeganbob
Year and Model: 1998 s70 glt
United States of America
Post by dwmeganbob » Mon Sep 16, 2013 3:50 am
Just curious - did you consider cutting through the floor to replace the fuel pump?
jpr0204
Post by jpr0204 » Thu Oct 10, 2013 12:09 pm
Hi dwmeganbob,
Sorry it took so long for me to respond to your question. Just noticed it today. LOL!
I didn't really consider cutting through the floor only due to the fact that no matter how well you seal the cut up and seal it off there is always that chance of water leakage as well as corrosion setting in. And once rust starts, it's a real pita to kill unless you cut out all of the affected area and weld in new metal.
Not really something I have the heart to take a chance on consider there is not one spec of rust currently on the car.
- Joe
Current Vehicles:
jpr0204
Post by jpr0204 » Thu Oct 10, 2013 12:18 pm
09/26/13 - 110,450 Miles – The Volvo started to shake violently upon start-up then the “check engine” light came on. I hooked up the scanner and found a P0302 “Cylinder #2 Misfire Detected.” Found that the cylinder # 2 ignition coil had failed. I purchased one ignition coil and 5 new Bosch FR7DPP+ spark plugs. I then cleared all codes from PCM, and verified that the misfire had gone away. The misfire did clear up and vehicle now runs like new. - $50.00
10/05/13 – 110,575 Miles – I purchased a premium Mahle oil filter, 7 quarts of Cam 2 Pro-Max Synthetic Blend motor oil, and a Dorman oil filter housing cap and performed an oil and filter. - $30.00
Current Vehicles:
jpr0204
Post by jpr0204 » Sat Apr 05, 2014 9:36 am
04/05/13 - 113,850 Miles - I purchased a premium Mahle oil filter, 7 quarts of Cam 2 Pro-Max Synthetic Blend motor oil and performed an oil and filter change. While vehicle was up in the air, checked front angle gear fluid level as well as the rear differential oil level, both were okay and at their proper levels. - $17.30
Current Vehicles:
jpr0204
Post by jpr0204 » Thu Jul 10, 2014 2:23 pm
12/07/13 - 111,825 Miles - Performed tire rotation and balance - N/C
Current Vehicles:
jpr0204
Post by jpr0204 » Thu Jul 10, 2014 2:25 pm
12/28/13 - 112,000 Miles - Had PA State safety inspection and an emissions inspection completed. Car passed with flying colors, Brakes like new, tires like new, front end is tight, all lights are great. - $50.00
Current Vehicles:
jpr0204
Post by jpr0204 » Thu Jul 10, 2014 2:27 pm
01/11/14 - 112,381 Miles - Purchased a replacement p/s hose - $13.40
01/11/14 – 112,381 Miles – Replaced P/S hose from res. to pump as I had a small leak - N/C
Current Vehicles:
jpr0204
Post by jpr0204 » Thu Jul 10, 2014 2:28 pm
04/04/14 - Purchased a Mahle oil filter and 6 quarts of CAM2 10W-30 motor oil - $17.30
04/05/14 – 113,850 Miles – Performed an oil and filter change. While the car was up in the air, I had checked the front angle gear fluid as well as the rear differential fluid. Both were okay and at their proper levels. – N/C
Current Vehicles:
Who is online
Users browsing this forum: No registered users and 1 guest
